  • June 30, 2025, 08:19:43 PM
Author Topic: Do you fly all your models?  (Read 5170 times)
Offline John Fitzgerald
  • No longer an AMA Member
« on: January 30, 2012, 08:32:48 PM »
If you posess multiple models, do all of them get flown regularly, or do some just hang on the wall?
Re: Do you fly all your models?
« Reply #1 on: January 30, 2012, 08:49:25 PM »
Mine never get completed.  n~
A-Jet
« Reply #2 on: January 30, 2012, 08:56:07 PM »
I have a lot of wall hangers and floor sitters.
Offline Garf
    • Hangar Flying
« Reply #3 on: January 30, 2012, 09:09:23 PM »
Out of around 18 models, I fly 3 or 4 of them regularly.
Dwayne
« Reply #4 on: January 30, 2012, 09:16:45 PM »
Yeah I have a bunch of wall hangers and floor sitters...sigh hope to fly em all some day.
« Reply #5 on: January 30, 2012, 09:30:06 PM »
When I have a stunt plane, I fly the dickens out of it.  I have a bunch of combat planes that are too frightening to fly.
« Reply #6 on: January 30, 2012, 09:39:47 PM »
I have several - but usually only ever have 2 planes per season that are in Comp spec trim.
This year being the exception - with only 1 in Comp spec - however the engine is out of that currently.
I've given a few of the older ones away to make space for newer fleet - I do also have 3 that are Unflown  ~^
I think that is a more interesting question : Do you have planes that remain unflown for various reasons. - The only reason I have 3 that are unflown is becasue the engines they were built for stayed in my comp ships and were serving well - I would need to pull it out and start the trim process again for that I need time. Most of my time is spent building. I've got a new one getting close to paint its for the 2012 season.
Offline Dennis Moritz
« Reply #7 on: January 31, 2012, 04:30:14 AM »
I wind up flying almost everything that is flyable. Usually 6 to 8. Most of the wall hangers and floor sitters are busted up and in need of repair. Might sit like that for years until the mood hits. Or. I realize the obvious, "it ain't really that bad." To quote Dan Banjok's benediction, a benediction he intones over every crash I've seen him witness. No matter the height of the balsa dust, kicked up at impact.
Offline Chuck Feldman
« Reply #8 on: January 31, 2012, 05:48:12 AM »
I have two that I can fly. A Smoothie and a bi-slob. I do not fly the slob much. A lot of my models are in various stages of repair and or refurbishment. My shop is full of unfinished models. Looks like I am like many of you.
Chuck Feldman
AMA 15850
Offline Tom Niebuhr
« Reply #9 on: January 31, 2012, 06:11:54 AM »
The airplanes that I have hanging are mostly very high time and retired. Since the '60s I have never had a backup competition stunter.
My "Top Hat" is now 10 years old. I am building two new stunters and hopefully will have one completed late this year. The only active airplanes I have right now are the "Hobo" prototype. the "Curtiss Swift" that I built for VSC, and the "Jerseyan" which is about 6 years old. I hope to fly the "Sea Vixen" soon.
Unfortunately I will not make it to VSC. I will have eye surgery next Tuesday (cateracts), the other eye will be about a month later. That puts it right at VSC time.
AMA 7544
« Reply #10 on: January 31, 2012, 10:28:10 AM »
When I was flying a lot and trying to be somewhat competitive, I flew mainly just my "contest" models.  Occasionally I would fly a Classic ship to see if I wanted to fly it at a meet.
I have not flown since "Stuff Happened", but I will have three new planes, at least, to work out with.  Two "PAMPA Class" stunters and a Classic stunter.  Plus a profile or two for that class.  Going to have to start back slowly, though.
Back in the day, I flew everything I had as often as possible, but I can no longer do that.
BIG Bear
RNMM/AMM
« Reply #11 on: January 31, 2012, 10:34:07 AM »
It depends. I have a couple of very capable planes that just hang on the wall. Backups, I suppose. Usually there is one plane I fly a lot, a couple of others that get some flying and some that just hang.
« Reply #12 on: January 31, 2012, 11:12:53 AM »
Hopefully, this year I will get all the unflown planes flown.   Running ideas thru my head  for stooges for the combat planes and planes without wheel/landing gear.   Ringmaster marathon was the most flying I did for 2011.  Also I am getting tired of sanding on the P-47. H^^
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #13 on: January 31, 2012, 12:03:40 PM »
I don't have room to store airplanes I'm not using so usually give them away or donate them to the club raffle. Right now I have 8 that I fly as often as I fly which isn't allot. Two profiles both with Saito 40's, two PA ships with Saito 62's one Classic ST 51, OTS Ringmaster Fox 30 and 2 carrier airplanes.
« Reply #14 on: January 31, 2012, 12:20:22 PM »
In my part of the world, good weather days are scarce.  Flying time is much less than I would like. My building time is steady and constant.  Therefore, my "hangar" contains at least 25 planes, ready to go.  There are at least 3 that are still waiting for initial flight.
F.C.
Online Matt Colan
« Reply #15 on: January 31, 2012, 03:27:27 PM »
Out of the 6 I have, 3 are flown on a very regular basis.  My first plane, an ARF Smoothie is a flying deathtrap, where even the glue seams are popping loose, so that plane has been stripped of everything and just hangs on the wall almost like a museum piece.  My profile Fw-190 has become a trainer of sorts for anyone that ever wants to learn how to fly.  my little cousin has taken a flight on it, and we should be getting him more air time this year.  My ARC smoothie hasn't been flown since Brodak 09.  The Ares I still fly on a semi-regular basis, but I haven't flown it since the NATS.  That plane is almost like an old friend, and it's still fun to fly.  My Oriental Plus I still fly on a regular basis, since I've spent quite a long time getting it in better trim.  The Trivial Pursuit I will get back to flying come the spring, but I haven't done much with it since it crashed.
Offline David M Johnson
« Reply #16 on: January 31, 2012, 03:55:20 PM »
I'm so glad I'm in good company!
I have some that I fly but more that I don't.
David Johnson
We're havin some fun now!!
Offline Terrence Durrill
« Reply #17 on: January 31, 2012, 04:04:30 PM »
Yes, I could have written most of the above comments myself.  Sounds like, as we get older, we talk more than we fly........I'll buy that.....TDurrill  LL~  D>K  H^^
« Reply #18 on: January 31, 2012, 04:59:24 PM »
2 hangar queens left....the Phaeton II K&B .61 and a repaired scratch and dent, Nobler ARF with McCoy/Testor's .40 ! Plan to get then christened this spring, but who knows. :P
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #19 on: January 31, 2012, 05:46:38 PM »
I have 9 flyable Sport and scale models, I was able to fly all 9 last year, however some ony flew once, while others flew lots of missions. I generally have 3 or 4 that flown a lot while, the others are flown once or twice enough to keep the motors and systems working.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Eric Viglione
« Reply #20 on: January 31, 2012, 06:03:46 PM »
No, I dont. And the last couple years I was flying the worst ones the most instead of just practicing with my better contest planes, much to Fitton's dismay...LOL.
Couldn't help it, just hard to give up trimming on a lost cause.
But hey, I learned a lot, it kept the mileage off the good planes and it just feels that much better when I do get around to flying them.  LL~
EricV
« Reply #21 on: January 31, 2012, 06:07:03 PM »
I fly one for each class, like AMA and Classic, Old Time, and the older ones hang on the wall.
Chris...
Offline Lester Nicholson
« Reply #22 on: January 31, 2012, 07:12:54 PM »
9 ready to fly, and yes they all get flown.  Nick
Offline Jim Hoffman
« Reply #23 on: January 31, 2012, 07:15:38 PM »
I am like Chris,  I fly one for each class; AMA, Classic, Old Time, and Profile and the older ones mostly hang on the wall.  I will occasionally fly an older one if the need or desire arises
This past year I had reason to fly one of my old AMA stunters (21 year old airframe, still looks good, ST-60).  It was revealing how many trim changes I made based on what I'd learned and a warp that somehow crept in over the years.
Jim Hoffman
Online wwwarbird
« Reply #24 on: January 31, 2012, 08:03:48 PM »
 At last count 25 models hanging on the wall that are complete and RTF at a moments notice.
 About 6 or 8 of them flew this past season.
 400 or so to build yet. ;D
« Reply #25 on: January 31, 2012, 08:10:26 PM »
models you dont fly? if I did that I would not fly, heck mine dont live long enough to get archived LOL  HB~>
Online wwwarbird
« Reply #26 on: January 31, 2012, 08:13:28 PM »
 So Mark, is the 109 the longest you've owned a plane then? (DOH!) :##
« Reply #27 on: February 01, 2012, 05:55:18 AM »
I see pick on Mark again.   I want to be there when he gets even.   I forgot to mention racing planes I have never flown as I am a much better pit man than pilot. H^^
Offline Dalton Hammett
« Reply #28 on: February 01, 2012, 08:12:57 AM »
I hear about that from my wife all the time,  "All these planes and I only see you fly the same three all the time".
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
« Reply #29 on: February 01, 2012, 10:13:00 AM »
There are two planes I fly a lot,a classic and a pampa plane. I have twelve flyable planes but most are seldon flown as they are 12-50 #^ years old. This year I flew two that were built buy a friend in 1952 n1
« Reply #30 on: February 01, 2012, 11:02:14 AM »
Wayne,, cute, really really cute,, you just wait,, your turn is coming,, ( but based on me,, it might be a LONG LONG time coming)
I actually have my first fancherized twister in the rafters,, but its uh, well suffered to many indignities,, the wing is fractured inside the fuse,, so I have it, just dont want to fly it,,k
Offline Russell Shaffer
« Reply #31 on: February 01, 2012, 01:23:02 PM »
Mark, why don't you give that Twister to Tim?  He's probably bored with the Streak by now.  Actually, I should take my own advice. I think I have a couple that he could work on.
« Last Edit: February 01, 2012, 06:56:00 PM by Russell Shaffer »
Russell Shaffer
Klamath Falls, Oregon
Offline Bruce Perry
« Reply #32 on: February 01, 2012, 05:40:55 PM »
All are flyable, 7 large PA planes, many classic and Old time planes, I have every airplane I've competed with.  I usually only fly one competition airplane until after the contests are over then spend the time experimenting until the snow flies.
I have an Impact on skis for the winter flying.  It has a PA 40 and Pipe just like it did at the 95 Pasco nats...
All are alive and well.
B
« Reply #33 on: February 01, 2012, 06:57:02 PM »
Bruce, can you post a picture of the Impact on skis?  I can use a good idea.
Russell Shaffer
« Reply #34 on: February 02, 2012, 12:06:52 PM »
Chris...
HI Little Brother!
I did that same thing for a LONG time.  Now that I only get to hit local meets, I try to fly one plane in Classic/Nos. 30 AND PAMPA class.  Saves room traveling and I am not getting practice time so not having to switch works out well.  I might even built a Profile to meet all three classes and use it as a back up/bad weather flier.
BIG Bear
RNMM/AMM
« Reply #35 on: February 03, 2012, 05:42:52 AM »
Hey, I flew the Brodak Nobler in Old Time,  Classic and Intermidiate when ever it was possible.   Was laughed at a few times while flying it in  Old Time. H^^
