  • July 14, 2025, 08:16:33 AM
Author Topic: Sky Streak - Pic added. Streak Master Pic added.  (Read 7485 times)
« on: November 23, 2011, 09:09:21 AM »
Well now that the Vector is done I am back to work on the Sky -Streak. ( Or maybe a FliteRay)
I got the idea from Andrew Hathaway. I made a SkyRay fuse and will use the wing and stab from the Flight Streak.
I am using some of the knowledge I learned from Jim while building the Vector. ( The correct way to apply silk span to the fuse. Working off lines on the fuse to ensure the wing is in straight. I will also use his method on doing fillits.
I did call the Tech support guy to get his approval to glue the wing in. This way if there is any problems at all I can blame him for it. LL~ LL~ LL~  (inside joke for Zuriel and Louis)
« Last Edit: November 25, 2011, 12:37:58 PM by Paul Taylor »
Offline Mark Misegadis
Re: Sky Streak - Pic added.
« Reply #1 on: November 23, 2011, 09:45:07 AM »
Wow.. it looks pretty cool! When you say Sky Ray.. are you talking the 1/2a Sig plane?
Not to rain on your naming parade here but while you are still in creative mode you might want to find another name. Larry Renger has a little 1/2a stunter he is developing named that. Of course you can go buy a nice little rubber powered plane on the Guillows rack still to this day with that name.
http://stunthanger.com/smf/index.php?topic=23531.0
The article is in the November issue of Flying Models.  I hope you guys like it!  Larry Renger
http://www.guillow.com/skystreak.aspx
Also taken are Streaking Clown (it’s a good story) and Scat Streak!
Looks like a fun project. Good luck !
Mark
« Reply #2 on: November 23, 2011, 09:50:24 AM »
Looks good!
Wing covering material?
CB
« Reply #3 on: November 23, 2011, 10:06:58 AM »
Thanks guys. Just a knock around / trainer type plane but there is always room to make it better right?
It is a .35 size Streak. But I run it with a FP .25
Wing is monokote, fuse and rudder are silk and will have rattle can paint. Going to add a CF pushrod with ball joints.
What's in a name?
From the side it will look like a SkyRay, from the top it it will still look like a Flite Streak.
So here is a contest... using these letters what can I call it.
kaertsetilfyaryks
(keep it clean) <=
« Reply #4 on: November 23, 2011, 10:22:57 AM »
I know... I can call it Himmel Streifen
« Reply #5 on: November 23, 2011, 10:25:47 AM »
I used some of those letters..... ;D
Perhaps not:
Sod Buster
Escavator
Dowsing ShhTick
Perhaps:
Falken
Spud Runner  (This one may be in the wrong list)
Mowhawk
Sprint Streak
Rickety Ray
Sky Writer
Caliente
Medicine Man
Vindicator
Taylors Swift
« Reply #6 on: November 23, 2011, 11:24:26 AM »
I think you got it right the first time!
"kaertsetilfyaryks"
Look, I'll make the lettering graphic for free! Any color any size.
CB
Offline Bill Heher
  • Fix-it
« Reply #7 on: November 23, 2011, 01:16:31 PM »
Sky Freak
Freak Ray
Streak Ray
Fry Ray
Bill Heher
If it's broke Fix-it
Offline Zuriel Armstrong
« Reply #8 on: November 23, 2011, 01:32:40 PM »
Good job Paul....a scratch built ARF VD~
Zuriel Armstrong
AMA 20932
« Reply #9 on: November 23, 2011, 02:52:39 PM »
"kaertsetilfyaryks"
CB
CB
I will take you up on the offer.  I like it too!
Or ykskaerts might be better.
« Reply #10 on: November 23, 2011, 03:23:29 PM »
Airtestskyflyer
Zuriel Armstrong
AMA 20932
« Reply #11 on: November 23, 2011, 03:52:58 PM »
I won't play you in scrabble.  LL~
« Reply #12 on: November 23, 2011, 04:10:56 PM »
Use the "Sky Streak" name. If I remember correctly, Sal Taibi published a hot "C gas" free flight by that name in FM, so it had been used before Larry's 1/2a design. This should be a very good flying combination, regardless of what you decide to put on the wing. I would suggest putting your AMA # where the "Flite Streak" is, and the name on the inboard wing, per the rulebook.   y1 Steve
Online Larry Renger
« Reply #13 on: November 23, 2011, 04:12:59 PM »
How about "Streaksky"  Clearly inwented by the Russians!  LL~
Offline pipemakermike
Re: Sky Streak a Keil Kraft Kit from 1950
« Reply #14 on: November 23, 2011, 04:23:37 PM »
It seems to be a popular name.
Mike Nelson
« Reply #15 on: November 23, 2011, 04:52:41 PM »
I'd say call it whatever you like.  The name "Skystreak" has been used before and it'll be used again.  I used it back in 1994 on my hybrid Skyray 35/Flite Streak, I'm sure I wasn't the first and I won't be the last.  If you really want to kick the bee hive call it the worlds best Ringmaster.  #^
« Reply #16 on: November 23, 2011, 06:04:09 PM »
I think it should be called the Streakaway. Andrew's fly great.
« Reply #17 on: November 23, 2011, 07:13:08 PM »
Paul,
Decide on a name and I will provide the graphic.
Great plans, Sky Streak! That's a great looking model. Be much better larger.
Anyone ever build one? A Larger one?
Want to?
CB
Online John Paris
« Reply #18 on: November 23, 2011, 08:27:10 PM »
Paul,
If you were not getting so good I would suggest something like "Turfbuster" or "Worminator".  Skystreak is probably going to work.
John Paris
269
« Reply #19 on: November 23, 2011, 08:43:02 PM »
Paul,
Want to?
CB
CB
Surprise me.  I will PM my address.
Offline Garf
    • Hangar Flying
« Reply #20 on: November 23, 2011, 09:36:03 PM »
How about "FUBAR"?
Offline Guy B Jr
« Reply #21 on: November 23, 2011, 11:37:31 PM »
FUBAR was the name of a FF kit in the early 1950's. Was cute with the anhedral tips on the stab.
Guy Blankinship
« Reply #22 on: November 24, 2011, 06:08:56 AM »
Plastic Surgery :-*
Zuriel Armstrong
AMA 20932
Offline John Desrosiers
« Reply #23 on: November 24, 2011, 06:29:44 AM »
        I kinda like (snafu)
Offline Tom Niebuhr
« Reply #24 on: November 24, 2011, 06:35:11 AM »
How about: Morph or Mutant.
Or remembering that famous song of a few year ago, leave the fuselage in clear and call it "The Streak".
AMA 7544
Offline Willie Johnson
« Reply #25 on: November 24, 2011, 11:14:41 AM »
You're becoming a master builder.  Share the knowledge on the correct way of doing things.
Willie
Willie Johnson
AMA 774461
« Reply #26 on: November 24, 2011, 11:25:17 AM »
I'm no where close to being a master builder. You have access to the same guy that is teaching me. Jim "The Bearcat" man.  y1
Online Larry Renger
« Reply #27 on: November 24, 2011, 03:50:46 PM »
I have had a number of requests for a .40 size version of my Sky Streak and Eric Rule says "Bring it on!"  If I draw it, he'll make parts available.  I may make a full fuselage rather than the profile.
Offline RDJeff
« Reply #28 on: November 24, 2011, 05:10:06 PM »
Does anybody know where I can get plans for that Sky Streak?  I have a D-C Spitfire that needs a home, and that looks to be a good plane!
Offline George
  • Love people, Use things.
« Reply #29 on: November 24, 2011, 05:42:00 PM »
Flying Models 11/11.
George
George Bain
AMA 23454
Offline George
« Reply #30 on: November 24, 2011, 05:44:41 PM »
Paul,
How 'bout "Streakin' Paul".  >:D
George
George Bain
AMA 23454
« Reply #31 on: November 24, 2011, 09:25:25 PM »
How about there are already too many models with "sky" and "streak" in the name.
Online Larry Renger
« Reply #32 on: November 25, 2011, 12:20:02 AM »
You are probably right about the name, but pretty much all my recent models have the "Sky" prefix, and I wanted to pay homage to Scarinzi's "Streak".  What else could I do?
Sky Slash
Sky Dancer
Sky Fire
Sky Rider
Sky Blaster
Sky Streak
I probably am forgetting one or two.  At least I have thrown in Toucan, Cheechako, CliffHanger, Cutlass II, Zombie Terror and Zippie Dragster.
« Reply #33 on: November 25, 2011, 05:42:35 AM »
If you mean the KK Skystreak 26  I can expand the plan up to full size in PDF format if you like.  It will be a bit blurred but good enough to build one.
Email me and I will send it
Mike Nelson
« Reply #34 on: November 25, 2011, 07:46:45 AM »
Paul, you said I could name your model and I have. "The Streak Master."
OK, now with the introduction of a fine looking model from Mike. The Skystreak. Mike are you hiding other great designs?  ;D
Gee, I gotta say this, the fuselage on this looks much like my "International." Good thing I drew the "International's" fuselage in 2009 and can prove it.  n~
I have all I need to draw this model at any scale in vectored format. I also have connections with a laser cutter. I will absolutely make one for myself, possibly with some small changes. Sure, it's fun to have someone through a model into the air, but mine will have gear.
I would never build this thing at 26". The only engine I have that small is a rubber band.
If you "really" want one of these models, you can contact me if you choose. AND if there's enough interest,  maybe a game plan can be put in action. "Gotta love it when a plan comes together."
As I said, I will build one of these models for myself, with a few changes.
OK, the new name of my model ?
"The Streak Master II"
CB
« Last Edit: November 25, 2011, 08:23:29 AM by Avaiojet »
Re: Sky Streak - Pic added. - Streak Master Pic added
« Reply #35 on: November 25, 2011, 12:36:22 PM »
The Streak Master is coming together.
Working on the controls now.
Re: Sky Streak - Pic added. Streak Master Pic added.
« Reply #36 on: November 25, 2011, 05:04:49 PM »
Paul,
I see something on your building bench I've never seen before?
A bunch of pins with pronunced red "pinheads?"
I could use a bunch of these.
Supplier?
CB
Offline Bill Heher
  • Fix-it
« Reply #37 on: November 25, 2011, 05:47:10 PM »
Jim Snelson has those pins in stock at CLC, I picked some up last time I was there. I think they are DuBro- nice sharp pins and easy to handle.
Bill Heher
« Reply #38 on: November 25, 2011, 06:44:50 PM »
Got mine from Tom Morris.
Offline RDJeff
« Reply #39 on: November 30, 2011, 05:07:33 PM »
D'oh!  Evidently my Spitfire has grown up, and is now a Sabre!  I guess I'll expand the plan a bit, maybe go from a 26" wing to a 33".
