  • July 14, 2025, 02:15:17 AM
Author Topic: Sizzix Cutter, cutting 1/16 balsa  (Read 822 times)
Offline George Albo
« on: August 21, 2016, 11:03:16 AM »
Here is the Sizzix Cutter, cutting 1/16 balsa. This might be of interest to some. The cutter can be programmed via your PC. No modules involved.
https://www.youtube.com/watch?v=QRvv4myOlFI&feature=youtu.be
George Albo
Offline George Albo
Re: Sizzix Cutter, cutting 1/16 balsa
« Reply #2 on: August 21, 2016, 03:15:32 PM »
I want that!
https://www.amazon.com/Sizzix-eclips2-Starter-Kit-Version/dp/B00IXFMH2S
That puppy is on my must have list!  It uses a high speed cutter similar in function to a dremel or router. Any corners need to be filed square (big deal small inconvenience).
Check this out: http://www.hippocketaeronautics.com/hpa_forum/index.php?topic=19248.0
