  • July 15, 2025, 04:38:00 PM
Author Topic: Similar Terminology  (Read 1065 times)
Offline Rusty
Similar Terminology
« on: June 23, 2025, 10:58:35 AM »
Hello,
Just wondering.
When an R/C airplane engine quits in flight, it is called a "Dead Stick."
When an U/C airplane engine quits in flight, is that called a "Dead Handle?"
Offline Peter in Fairfax, VA
Re: Similar Terminology
« Reply #1 on: June 23, 2025, 11:58:01 AM »
Dead stick refers to the prop, I always thought.
« Reply #2 on: June 23, 2025, 12:09:11 PM »
  In full scale parlance, you will be found "dead at the stick"  if you run out of airspeed, altitude and ideas all at the same time!!  Peter may be correct. With no power and the prop just a decoration on the nose, it's just as useful as a dead stick!!
  It's like the question, why do we drive on a parkway and park in a driveway!! The English language can get all jumbled up with slang and these days it's just getting worse! It wouldn't be this way of people didn't accept it as "normal." Especial in business dealings, even if it's shopping and checking out at Wal-Mart!
Offline Dave Moritz
« Reply #3 on: June 23, 2025, 01:24:18 PM »
My small engine shop teacher, back in 1969, told us guys that every engine was a one cycle engine. There was no such thing as a “two cycle” or “four cycle” engine. He went on to explain that some engines had four strokes per cycle while others had two strokes per cycle. I see that many petrol product producers refuse to correct the error and still don’t use correct terms like two stroke and four stroke.
So there you have it, welcome or not!
Dave Mo…
Offline Rusty
« Reply #4 on: June 23, 2025, 05:46:47 PM »
Interesting.   I thought the stick part was because the term was coined when aircraft had sticks to control it, not a yoke.  Why would they call the propeller a "stick?"  Why not "dead propeller" landing?
So, okay.  A landing with the engine running would be a "live stick" landing.  Right?
Offline Rusty
« Reply #5 on: June 23, 2025, 05:48:49 PM »
Dave Mo…
Okay.  Why did they call them "internal combustion" engines?  Was there an "external combustion" engine?
Offline John Rist
« Reply #6 on: June 23, 2025, 08:51:30 PM »
Yes! it's called a steam engine.  y1
Offline John Park
  • Agricola
« Reply #7 on: June 24, 2025, 03:36:10 AM »
In the early days of aviation, props. were generally two-bladers, made of wood - the 'stick'.  When it wasn't going round, it was 'dead'.  A landing with the prop. stationary was a dead-stick landing - depressingly common in the not-so-good old days of unreliable engines.  The control column, or 'joystick', had nothing to do with it.  It really is as simple as that.
Offline Rusty
« Reply #8 on: June 24, 2025, 06:25:58 AM »
John Rist and John Park are stunt hangar jeopardy champions.  Congrats
« Reply #9 on: June 24, 2025, 06:58:29 AM »
   They are internal combustion ENGINES, because that is where the power is produced for it to run. It's the difference between a MOTOR and an ENGINE. I was taught that an ENGINE produced it's power internally through the use of fuel. As such, and IC ENGINE requires fuel that by itself, just sits there. STEAM ENGINES produce their power internally from a fired boiler that is fed fuel such as wood or oil. A MOTOR, such as an electric MOTOR, requires the power to be introduced to it from another source, such as a battery or an electrical cord. I think devices driven by compressed air or compressed CO-2 are considered motors. And I'm sure that these points as presented can be argued about all night if enough beer is present to fuel the discussion, which would make that discussion and ENGINE!!, I think!!!
« Reply #10 on: June 24, 2025, 05:18:03 PM »
So, should we call an 8" long 1/2" square piece of maple an "Engine Mount"?  I guess some do.  Maybe that is why Detroit died.  They found out cars used engines and "Engine Town"?   Nah
Offline Rusty
« Reply #11 on: June 24, 2025, 06:02:24 PM »
 What classification is the a "rubber band motor?"  It may be an internal energy motor, due the stored power of the twisted rubber band.
« Reply #12 on: June 24, 2025, 06:31:39 PM »
It's a mogine.  Z@@ZZZ
« Reply #13 on: June 24, 2025, 08:51:58 PM »
   I knew a guy many years ago who sprayed crops with a Stearman biplane. He swore that the prop was to keep the pilot cool. He said when it stopped, the pilot would begin to sweat.
  He also sprayed crops next to a lake, and had to make his turn arounds over water. He said as soon as he got over water the engine would begin to run rough, but as he headed back toward land it began to smooth out. He admitted it was his fear of having to land in the water that made him think the difference in the engine over water or over land.
   Dead stick has always meant the prop has stopped. In control line stunt, we always land dead stick. Free flights also land dead stick. Before my Grandson became an airline pilot, he use to fly pipelines. After having to land on dirt roads twice from engine failure, he did other things to support his schooling to get His commercial airline pilots license. The pipeline flying company he worked for were a little lax in maintenance. He knew what dead stick meant first hand.
Offline Rusty
« Reply #14 on: June 25, 2025, 03:47:42 PM »
Nice story.   My post is made under the literary term: humor.  However, you must note that I have made C/L landings that were live stick and they broke the stick, referred to by some as a prop.
« Reply #15 on: June 25, 2025, 06:58:44 PM »
     Ha hA! That is not dead stick, that is broken stick. Been there done that. Hooked lines up backwards, and as I eased in up elevator the stick got ground down to a facsimile of a prop. We must keep separation between dead stick and broken stick. LOL. Diving into the ground is broken stick, along with many other parts. IT is also called a really bad day, in some circles.
Offline John Park
  • Agricola
« Reply #16 on: June 29, 2025, 02:47:42 AM »
I've got a book the size of a cinder block, called 'A Dictionary of Slang and Unconventional English' by Eric Partridge.  Its definition of 'dead stick' is as follows: 'dead stick is applied to the controls of an engine that has stopped: RAF since ca.1925.'  Make of that what you will!
« Reply #17 on: June 29, 2025, 08:35:22 AM »
Why would they call it a "dead stick" when the stick becomes easier to move and it is not the stick that is dead?  Unless of course you lost hydraulics, but then you would probably have a "bad yoke".  H^^
Offline Steve Dwyer
« Reply #18 on: June 29, 2025, 08:54:57 AM »
I've always thought of an internal combustion as an air pump. A large enough intake manifold and carburetor measured in CFM and big enough exhaust ports to prevent back pressure. While it spins it produces power.
« Last Edit: June 30, 2025, 06:26:56 AM by Steve Dwyer »
Online Motorman
« Reply #19 on: June 29, 2025, 12:01:50 PM »
When a control line engine quits it's called a burp.
Offline Steve Dwyer
« Reply #20 on: June 29, 2025, 02:26:04 PM »
Or quite possibly an Oh S_ _T
Online Dick Pacini
« Reply #21 on: June 29, 2025, 03:03:39 PM »
And when a CL stunter goes straight in it is called a lawn dart, regardless if the prop is rotating or not. ;D
AMA 62221
Offline Rusty
« Reply #22 on: June 29, 2025, 04:15:37 PM »
Just wondering if when you are flying your control line plane and you fly (accidently) into the sun, where you can't see your airplane; is that called "sun block?"
« Reply #23 on: June 29, 2025, 04:44:26 PM »
No, that is called Tuesday.  The wind follows the sun, and the clouds are timed to part just as you commit to an RWO.  The references in the rule book should be rewritten to show the sun directly downwind at 45 degrees.  It is always there.
Offline Steve Dwyer
« Reply #24 on: June 30, 2025, 06:33:29 AM »
I've heard an expert say close one eye when caught trying to eclipse the sun with your model. Light adaptation can vary depending on the individual.
« Reply #25 on: June 30, 2025, 08:04:36 AM »
In my aging case, look at the sun and I am blind for about a second or more.  If the wind is directly into the sun before about 11:00 I can either bias the maneuvers and have a crappy pattern, pick up the remaining pieces of my plane or roll up the lines.  I don't even go to the field anymore if the sun is directly down wind except at a contest.   Sun glasses help some but not enough.  It sucks.
Online Gerald Arana
« Reply #26 on: June 30, 2025, 09:02:21 AM »
or it could be called a "figure" 9......................and , yes, I've done a few of those.....
Jerry
Offline Rusty
« Reply #27 on: June 30, 2025, 09:40:09 AM »
When you hand start an engine with a non-electric tool, it is called a "chicken stick."  If you hand start an engine with your bare fingers, is that called "steak fingers?" (especially, if they become bloody rare fingers.)
Offline John Park
  • Agricola
« Reply #28 on: July 01, 2025, 07:53:52 AM »
Absolutely - I can't make any sense of it either!
