I ran across this information on RC Groups. I'm not sure about it. I figured I would let experts take a look.
"So..let's start with what I like to use product wise. Changing over to electrics 24yrs ago, really opened my eyes to alternatives other than true aircraft "dope". I often wonder why we ever felt the need for using "dope". But, it has been thought to be a requirement for generations. They only modeling intent dope that is really applicable to us is the old Aero-Gloss. And this is repackage automotive acrylic lacquer. It is low shrink and even more than nitrate dope, has superior adhesion.
My favorite "dope", is plain old hardware store brushing lacquer. This can be many different brands. Deft, Watco, Minwax, etc. The important thing is not to buy gloss. Get satin or matte. Some, like the Deft, have a very high white solid filler that usually is at the bottom of the can.(hopefully) I use a metal cup to take out the clearer lacquer and put in a working bottle. If you have a qt jar with metal top, just pour the clearer stuff into that. The filler at the bottom of the can is used for a balsa filler after thinning. I acquired much of this and congregate it in empty lacquer cans. This stuff really needs a lot of thinning, over 100%.
Speaking of thinning, using percentages is a very vague way of mixture control. Look for consistency of the thinning. It should be like water. Test by dipping the brush and watching the drip. No strings in the drip. Too thin is better than too thick. It just means an extra coat or two or more. The Watco seems to work well at a minimum of 60% thinner to obtain this consistency. The thinner dope dries faster, has higher penetration, sands easier, and does not form puddles under the covering surface. This giving a smoother consistent, uniform seal.
One very important tool, in our arsenal, is the brushes. These are called camel hair. But are actually squirrel. They must be seasoned to avoid loss of hair. Every so many years, I season a few new brushes. These are an investment. The most expensive brush I ever bought was a 4" camel at 42$ in 1980. Most brushes are 1/4"-1/2"W for our needs. Sometimes a 3/4" or 1" for large surfaces. Take that new brush, soak it in the thinned lacquer a few hours. remove and let harden a few hours. Put it back in the lacquer let it soak/let it harden. Do this as many times as it takes, so when wiping with a paper towel no hairs come out or maybe one or two. Now put it away for a week. It may still lose a hair or two till it is fully seasoned. Use the brush for wood sealing where sanding is required, till it is good for top sealing. NEVER clean your seasoned lacquer brush in thinner. Just wipe clean and harden. You can dry the brush after wiping by feathering over your fingers. Takes only a few minutes to soften for re-use."
