  • July 19, 2025, 01:32:18 AM
Author Topic: Sig Twister  (Read 2634 times)
Offline Dan Labine
Sig Twister
« on: July 03, 2007, 10:05:19 AM »
Does anyone make a foam core wing for the Twister?
Dan
MAAC 14300
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Sig Twister
« Reply #1 on: July 03, 2007, 10:08:21 AM »
Doubt it, the wing is an easy build and being constant cord easy to build straight.
Re: Sig Twister
« Reply #2 on: July 03, 2007, 11:18:56 AM »
I am sure that Crist Rigotti could do it for you, he is listed in the vendors corner. He did the cores for my bf109, they are great
Re: Sig Twister
« Reply #3 on: July 03, 2007, 11:28:39 AM »
Crist cuts some nice wings and at a fair price.
If he does not have the template you may have to provide him with one.
You may have to wait as he gets busy at times.
Offline Steve Scott
Re: Sig Twister
« Reply #4 on: July 03, 2007, 12:49:41 PM »
Didn't I see where Phil Cartier's Corehouse listed foam wing cores for the Sig Twister?
Yes I did.  http://home.earthlink.net/%7Ephilcartier/
Offline Crist Rigotti
Re: Sig Twister
« Reply #5 on: July 03, 2007, 01:13:50 PM »
Where?  I didn't see any mention of a Sig Twister.  How about more details please.
Offline Dennis Moritz
Re: Sig Twister
« Reply #6 on: July 03, 2007, 02:09:01 PM »
Phil Cartier of Corehouse sold a few of the Twister wings years back. Bought one at Lebanon.
Offline PatRobinson
Re: Sig Twister
« Reply #7 on: July 03, 2007, 05:43:03 PM »
Crist,
next to the picture of the Giles, under the ad for true beam wing, then down
you will see a price for $45.00. Now look under that in finer print and you will
see G500X tapered and TWISTER for $35.00
( I have no idea what a G500X or whatever it's called actually is?)
        Pat Robinson
Re: Sig Twister
« Reply #8 on: July 03, 2007, 07:35:09 PM »
Crist,
        Pat Robinson
I'll be darned.  Yup there it is in the not too easy to read print.  Thanks.
Re: Sig Twister
« Reply #9 on: July 04, 2007, 05:02:05 AM »
Of course they will have to wait until after the NATS to them, right Crist.  Have fun,  DOC Holliday
Re: Sig Twister
« Reply #10 on: July 04, 2007, 08:33:23 AM »
Yup Doc.  Email already sent.  See you at the NATS.  Have a safe trip.
Offline Bob Kruger
Re: Sig Twister
« Reply #11 on: July 04, 2007, 02:00:55 PM »
Crist cuts cores for the Hunt RD-1.  The RD-1 and the Twister wings are virtually identical in airfoil and dimensions.
I don't have one of Crist's RD-1 cores handy right now, but the chord should be 8 1/4" less the flaps, and it should be 1 7/8" thick (including the sheeting)
Crist - if you have any RD-1 cores kicking around, would you do a quick measurement?
I've used both Crist's and Phil's cores.  Quality of both is without question.
V/r
Bob Kruger
Bob Kruger
AMA 42014
Re: Sig Twister
« Reply #12 on: July 04, 2007, 08:55:46 PM »
I remember discussing the RD-1 with Bob when it was "new".  My oldest, Aaron, and Robby got to be pretty fair Buddies, and Aaron built the RD-1 (with foam wings) to be his first Contest plane.  He now has a built up wing RD-1 for Profile class and practice.
We used the Webra 28 which when mounted sideways didn't have the burp that caused Bob to eventually swap the 28 out for a 32 in the Tucker he published.  Aaron ended up with all Bob's 28 parts, including the one that was used in the Tucker Special.  The Webra 28 is a strong little engine! y1
The RD-1 wing vs. the Twister............. same, same for all intents and purposes. ;D
Re: Sig Twister
« Reply #13 on: July 04, 2007, 09:08:12 PM »
The RD-1 cores are the same but the Twister cores are 3/4 inch longer.
Re: Sig Twister
« Reply #14 on: July 04, 2007, 10:35:11 PM »
Thanks, Crist.  I didn't even think about the WS.  A "minor" consideration...... **)
Offline Bob Kruger
Re: Sig Twister
« Reply #15 on: July 05, 2007, 12:56:29 PM »
Good point.  Something that can be easilly remedied by adding 3/8" or 1/2" tips, or just asking you to cut them to Twister length.... :-)
V/r
Bob
Bob Kruger
AMA 42014
