  • July 01, 2025, 01:58:00 AM
Author Topic: Sig Mfg  (Read 2815 times)
Offline Bootlegger
Sig Mfg
« on: January 20, 2018, 08:12:35 AM »
  Does Sig have a log in site where they contact you via email when they are running specials, also do they have a catalog site?  I am looking for a field support box, ao if anybody has a suggestion on this item please let me know.  Thanks,Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Matiska
Re: Sig Mfg
« Reply #1 on: January 20, 2018, 08:58:41 AM »
Of course. sigmfg.com is Sig's website. Peruse it to see everything they have, order from it, establish a user ID and password, sign up for their occasional email of new items and specials. I have, with no problems.
Bob in NEPA
AMA 56267
Offline Dane Martin
  • heli pilot BHOR
Re: Sig Mfg
« Reply #2 on: January 20, 2018, 09:41:42 AM »
Yep, click this to go to field boxes.
http://www.sigmfg.com/cgi-bin/dpsmart.exe/IndexFieldEquipmentF.html?E+Sig
When you buy something, you have to sign up am account. Then you get the "specials" and new products email.
Re: Sig Mfg
« Reply #3 on: January 20, 2018, 09:42:40 AM »
 They do, right here...
 Most of the Sig field boxes are big monsters though, designed more for the R/C guys. Hangar 9 offers one that is very popular and seen all over. It comes as a simple kit, just needing to add a control panel and a battery which they also sell. It's the one I've used for years, a handy smaller size but still holds quite a bit of stuff...
 http://www.hangar-9.com/Products/Default.aspx?ProdID=HAN130
 http://www.hangar-9.com/Products/Default.aspx?ProdID=HAN106
 http://www.hangar-9.com/Products/Default.aspx?ProdID=HAN102
Offline Sean McEntee
Re: Sig Mfg
« Reply #4 on: January 20, 2018, 07:10:34 PM »
If you have the required tools, Why not draw one up and build one yourself?  My dad and I built our own many moons ago. Dad still uses his. I have since gone minimalist and just take a glow igniter and tach out to circle.
Draw up what you think it should be, then build a mock-up with either cardboard or foam board. Use those as templates and build the final product. You will be able to build it to exactly suit your needs.
Either ways, good luck!
Re: Sig Mfg
« Reply #5 on: January 20, 2018, 08:07:09 PM »
Here’s a pic of dads.  Small and functional
Re: Sig Mfg
« Reply #6 on: January 20, 2018, 09:01:58 PM »
   Thanks to Sean for helping the old man out with the photo. Mine is just biog enough for the power panel and a 12 volt, 7 amp gel cell underneath it. I divided the other side in half for space in a simple drawer and an open top area for odds and ends, spare plugs, and a few tools. I just want all the power I can get for a good clean start, and the occasional use of a starter if necessary. It's made from hardware store luan wood, 1/4" thick, a simple rope and pvc pipe handle and some cord for a drawer pull. This is the second one I have built, after wearing the first one out. I used a the brass corner hardware from the first box on this one. Gave it a coat of some sort of urethane that I had laying around. Makes a good surface for stickers and such. The battery needs to be charged just twice a year or so. I used it today to get my January flights!
Offline Bootlegger
Re: Sig Mfg
« Reply #7 on: January 22, 2018, 04:41:50 PM »
 Fellow's I sure do appreciate all the help/advice, this afternoon I ordered one from Hanger 9 their model # han 130 if I remember right.  But thanks a lot.. #^ #^ #^
Gil Causey
AMA# 6964
Offline Tim Chenevert
Re: Sig Mfg
« Reply #8 on: January 23, 2018, 05:22:33 PM »
 Gil, you have one of the best field boxes on wheels I have ever seen! Tim
Baton Rouge Bi-Liners
AMA 179681
