After a while of flying profiles of various sizes I've graduated onto full fuselage models.
What I don't understand is what the elusive better run of the inverted motor is.
Currently my experience of inverted motors is that once I get them running the run seems acceptable, but not different enough from my sidewinder models to justify the difficulty I seem to have starting inverted motors.
I can fuel and prime any of my sidewinders and guarantee a start within a few flicks, often first flick, but the inverted motors are a pain, too dry, or flooded. So far I can determine no pattern in terms of what the difference is. If I follow steps ABC today first start, too dry. Second start, flooded.
I've had to resort to starting them inverted, but neither my flying buddy nor I are particularly happy about turning the model over with a nicely revving 45 or 60 in the nose. And as far as doing that whilst flying solo is concerned.....
My starting battery is a a cyclon lead acid and I use an ammeter to drop the voltage. The ammeter is quite useful as I can tell immediately in the sidewinders whether the motor is too dry or too wet, and with the lead acid I've got lots of capacity for colder mornings. According to my calibrated work voltmeter I get 1.5 V at the plug. All motors use Enya no 3 plugs. Fuel is 5% nitro, all castor.
So,
1) what is the advantage of an inverted motor over a sidewinder
2) How can I get my inverted motors to start promptly.
So far I've been using a mix of old and new motors inverted - ST46s, ST650s and (new) Enya 45s and the results are the same. I've grown very familiar with the irritated hiss of a flooded super tigre.
