I don't remember when I had posted about my Brodak 40 usin so much fuel, but I had commented that I had filled the venturi with J B weld and drilled it out to .272, wanted to try it but weather and other things had prevented it. Yesterday I got to fly it, and I was gettin 6:30 out of 4 oz 5% N 22% oil blended usin a Tbolt idle bar plug with 10x5 APC prop, model weight is 42 oz lines are 59' eye to eye and 5.2 lap times, plenty of power everywhere in the pattern.
I flew 4-5 times and the engine was very consistant, very steady, fairly deep 4 cycle breaking into a two at the right times...
I didn't "dress" the top of the ventuti, no taper, just left it flat, had some questions as to weather this would work or not, can report here that it worked just fine.
Just a follow up on an earlier post.. Hope that this helps some one else with questions...
