I personally have found that a handle such as what I have come to know it as "Ted's handle" tends to be more responsive.
They can be a touch tricky when adapting them to a new plane because of the adjusting of neutral.
In a perfect world all cables are the same length and there is no issue. In my world one cable is always longer than the other so I end up needing to use various length clips to attach the lines to the plane in order to make finite adjustments.
If you simply move the arm in or out, you are changing the turn ration (inside vs outside) etc.
Anyway, if you get a chance to try one do so and tell us what you think!
