Hey Jim:
After reading your question and the replies, I'm thinking that I don't understand what you mean by "using it as a pin". Do you have a picture you can post that explains it?
I think all of us are (or were) assuming you meant to use it as the rod between two ball links as, for instance, between a bellcrank and a flap horn.
(my take on what I thought your question was is that for the bellcrank to horn I'd rather use music wire, with threaded brass ends soldered on, and for the flap to elevator rod I'd rather use CF with 4-40 bolts at the ends. That's worked well for me).
What I mean is a small section of this wire, about 3/4 inch long or so, one end bent to an "L" shape, the other end going thru the clevis and horn to connect the clevis to the horn. This could be either flap horn or elevator horn. The other end of the wire would have some retainer on it, such as a wheel collar. In this case, the wire is used as a connecting pin, for lack of a better term.
Also, it could be used as a pushrod between flap and elevator. The threaded end would have a clevis, the other end simply bent to go thru the flap horn.
My concern is that with this wire being rather soft, it would wear quickly in the horn bushing when used as a small, separate pin or if simply bent and going thru the horn bushing.
