  • May 28, 2024, 07:01:14 PM
Author Topic: Veco 19 Venturi Size  (Read 689 times)
Online Motorman
« on: March 27, 2013, 02:18:16 PM »
blank
« Last Edit: September 05, 2021, 09:48:18 PM by Motorman »
Offline Garf
    • Hangar Flying
Re: Veco 19 Venturi Size
« Reply #1 on: March 28, 2013, 05:43:34 PM »
Ball bearing or plain bearing?
« Reply #2 on: March 28, 2013, 06:42:49 PM »
It might run with a .281" insert, but that's awful big for stunt purposes. My .25LA venturi is drilled out to .272" with .156" (K&B) spraybar. That's pretty large for a .25, which is itself roughly 25% bigger in displacement than a .19 (most .19's are .199 CID). I only did that because I was going to fly it in Reno at 4,900' elevation. I would suggest starting with .257" or .265" if you're interested in stunt or sport flying the .19. Also, remember that you can make the venturi "smaller" with multiple layers of pantyhose material. How you get the pantyhose material is best left unmentioned.  #^ Steve
« Reply #3 on: March 30, 2013, 06:13:47 PM »
A 9-4 MAS would be about 2.5" pitch, so don't think that's a useful prop! The MAS S-2 Scimitars are good props, also very underpitched, but maybe a 9-5 or 9-6 would work. The APC 9-4 and 9.5 x 4.5 would be on my list to try.  H^^ Steve
