Hello Brian and Jim,
My Mk2(?) doesn't have an anodised body and the single exhaust is not facing the side either (maybe an extra 30 degrees). Odd that two engines are the same, maybe Cox ran out of anodised bodies, or they are both rebuilds using a standard TD case. Who knows!
I shall send daughter a text re the cheque! I think she has probably forgot all about it, because after a VERY long time she is expecting a baby! If I say it is for baby cloths, then it will probably be cashed straight away! I will keep you posted, if she doesn't cash it soon, she will lose it!!
Best Regards,
Andrew.
P.S. Don't mind if it is a boy or girl, whatever, there will be a Tomboy built for the new arrival!
