  • July 18, 2025, 05:57:48 AM
Author Topic: Ringmaster Jr Landing Gear Question  (Read 1385 times)
Offline Chancey Chorney
« on: March 12, 2019, 08:55:41 PM »
Hi all. So, I am about ready to install the wing into my Ringmaster Jr I recently aquired. I had done some reading and determined that I will put in about 3/4 oz. of weight for the wingtip. If this is wrong, you can also correct me on it as well. But, the main question is related to the landing gear. I have a template of teh shape of the gear, but I am only missing one thing. Can someone please tell me what size of wire I need to buy to make the gear from? It is juat s Ringmaster Jr that will be powered by a Fox .15x engine if this makes a difference. Thank you.
Re: Ringmaster Jr Landing Gear Question
« Reply #1 on: March 12, 2019, 10:12:02 PM »
Thank you.
Offline C.T. Schaefer
« Reply #2 on: March 13, 2019, 05:26:15 AM »
3/32 better.   Save weight. Single wheel gear.
Offline Peter in Fairfax, VA
« Reply #3 on: March 13, 2019, 09:23:59 AM »
What size lines for the Jr. Ringmaster / Fox .15x combo?  0.012" x 45' ?
Offline dennis lipsett
« Reply #4 on: March 13, 2019, 09:47:06 AM »
If you want to spin like a top then use the 45 foot lines. Usual length is 52foot  and with a good 15X it will still be lively but manageable.
« Reply #5 on: March 13, 2019, 11:05:18 AM »
3/32" wire is standard for .15 sized airplanes...but I would suggest aluminum sheet (6061-T6) if you can make it yourself or get a rough blank from SIG. If you can deal with a single wheel or better yet, no LG at all, your RM Jr. will fly a bunch better. They're not stellar fliers.
For flying lines, 30 lb test Power Pro "Slick8" would be my choice, or the .012 x 52' cables. With the outboard mounted engine and tank, you won't need much tipweight with Spectra lines, saving a little more weight.  y1 Steve
« Reply #6 on: March 13, 2019, 11:37:39 AM »
Are you certain the Fox 15X will actually run?  Not all of them do.
Life is too short to spend it on a hurling engine.  LA 15.
My standard landing gear for that kind of plane is two-wheel, wing-mounted with .075" wire.  The way I set it up, I can upgrade to 3/32" if needed.
The wing gear swings back-and-forth, rather than spreading like a wishbone.
I don't like monowheel because it buggers-up the wingtip and tail tip.
Getting the landing gear out of the engine & tank are avoids some conflict.
Offline pat king
    • PDK LLC
« Reply #7 on: March 13, 2019, 01:27:08 PM »
My Ringmaster Jr. Kits use 3/32 Music wire landing gear. Slightly heavier, but stands up better to rough landings.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #8 on: March 13, 2019, 02:08:50 PM »
Actually all of the Fox 15X engines run. Some were put out with an extremely thick head gasket and it reduced the compression so much that it was a bear to start. If you change it out and put the correct gasket in they are an easy starter. I had over a dozen of them and they were always 3 or 4 flips and running. Ir puts out surprisingly good power if you take the time to really run it in. I just got rid of my last stash of them and was sorry to see them go as I had a lot of fun with them in the 60's. As a side benefit they are one of the lightest 15's you can own.
« Reply #9 on: March 13, 2019, 03:03:32 PM »
Thank you all for the help and replies. I will be using 52' x .012 lines on mine. I was hoping for a tamer flier, but it looks like I will have a lively little bugger! I never thought of solid gear. Well, I will be ag a stand still for a couple weeks then tilman i can make it back to the hobby shop to get some 3/32 wire for the gear. I wish I thought of it before when I was there.
« Reply #10 on: March 13, 2019, 09:45:49 PM »
I really like your method of mounting to the wing, paul, but I am unsure of how it really is mounted. My wing is already built and am thinking you may have beefed up the mounting area. Mine is just a 1/4" LE spar and 1/16" sheeting. I may have an in on thicker wire, but won't know till Friday. As for now all I have is 1/16" and I formed one, but it feels very weak to me still. I could go without gear, but I would then not be able to fly by myself.
