  • July 11, 2025, 07:26:15 AM
Author Topic: Ringmaster Build  (Read 10741 times)
Offline john ohnimus
Ringmaster Build
« on: September 03, 2015, 08:42:09 AM »
On to the Ringmaster.... So for the upcoming event in October, I am attempting to construct a Ringmaster S-1. Already have a good start on it. It will have a "Utility Finish" applied. And some simple graphics. Having fun so far. Pics to follow.
Hard Tellin'....  Not Knowin'
AMA 413710
Re: Ringmaster Build
« Reply #1 on: September 03, 2015, 08:44:31 AM »
Pic1
AMA 413710
« Reply #2 on: September 03, 2015, 08:45:17 AM »
Pic2
AMA 413710
« Reply #3 on: September 03, 2015, 08:45:56 AM »
Pic3
AMA 413710
Online Motorman
« Reply #4 on: September 03, 2015, 09:11:54 AM »
I have a feeling this will be the biggest Ringmaster fun fly of all time.
Offline John Kelly
« Reply #5 on: September 03, 2015, 01:01:07 PM »
   ...Hey John, If you look at the template for the rudder, You'll notice a  line 3/16" above the bottom. This is the Cut Line so you can glue the fin to the fuse and the rudder to the stab. Unless you have something against Up Elevator.   Cheers,  John
AMA 11416
« Reply #6 on: September 03, 2015, 01:46:27 PM »
Hopefully he will double check the plans.   The elevator is out behind the tail of the fuselage.   The last S-1 I built was from an RSM Mfg kit.   It is the lightest of the lot and has also survived a mishap at the field.
« Reply #7 on: September 04, 2015, 05:06:17 AM »
  All over it Guys!!! I was just sticking it together with pins for a progress shot.The real problem is with the # 7 rib... It was brought to my attention by another modeler, and sure enough it is just a bit smaller than the other ones and it is very difficult to tell unless you stack all of the ribs together. So for all of you scratch builders out there, do beware!!!
Apparently this is well known and I may be beating the dead horse here. This fellow also mentioned that the plans will state "Corrected # 7 rib" if it is the right rib profile. These are plans I downloaded from the Outerzone. Nice plans otherwise and an easy enogh fix.
 Also did some graphics last night, couldnt find any of the local sign guys to make me a Ringmaster decal for the wing, so I took a piece of silk span and taped it to a piece of copy paper and printed the image right onto the silkspan. I will dope that onto the wing after it is covered. I believe I hadread this in an old free flight article somewhere..
AMA 413710
« Reply #8 on: September 04, 2015, 05:19:15 AM »
Picture of the graphics for the Ringmaster...
AMA 413710
Offline Larry Borden
« Reply #9 on: September 04, 2015, 07:42:37 AM »
I had a sign shop make up a hundred of the Ringmaster decals/stick on. I have been selling them for 3 bucks, postage included.
Not fuel proof.
« Reply #10 on: September 06, 2015, 09:33:26 PM »
Progress..
AMA 413710
« Reply #11 on: September 06, 2015, 09:40:08 PM »
Progress..
AMA 413710
Dennis Leonhardi
« Reply #12 on: September 07, 2015, 03:47:02 AM »
Not fuel proof.
Great idea Larry, is the background white or clear?  Thanks!
Dennis
« Reply #13 on: September 07, 2015, 09:28:52 AM »
Looking good on the construction.  Hard part is getting leading edge to look right.
« Reply #14 on: September 07, 2015, 02:25:35 PM »
Background is white.
The latest one have the copyright symbol and date.
« Reply #15 on: September 07, 2015, 08:46:57 PM »
Doc,
 Been thinking about that one myself. I have a very nice low angle block plane that is very friendly. I think that will get me close. I plan to finish it with a long sanding bar. I was going to drill some hole in the LE but I chickened out. I was afraid the drill bit would chew it up. I ran a couple of test and it did not look good. I came across a molded built up LE from John Cralley on FB and I may build another RM and try that method. Wing is heavy for sure, hope to make it up in the fuselage.
Tony O
AMA 413710
« Reply #16 on: September 07, 2015, 08:48:59 PM »
Pic 1
AMA 413710
« Reply #17 on: September 07, 2015, 08:49:33 PM »
Pic 2
AMA 413710
« Reply #18 on: September 14, 2015, 07:59:56 AM »
Things are moving along quite nice now hope to finish up the wing this week and start covering everything this weekend.
AMA 413710
« Reply #19 on: September 14, 2015, 10:45:56 AM »
Looks great.   Planing, carving and sanding does take patience.
« Reply #20 on: September 15, 2015, 05:59:23 AM »
Yes it does? seems like I have spent alot of time shaping that leading edge. There is a molded leading edge I would like to try that looks really lite and should be a bit quicker, and probabally cheapr ($$). Other than that it has
been a pleasant experience. I have not built anything in 16 years, I have alot more tooling now so it seems easier. And again I can't thank the good folks on the Forum for all of the advice and support through out these last couple
of projects.
Tony O
AMA 413710
Offline Bill Johnson
« Reply #21 on: September 17, 2015, 11:48:12 AM »
Pic 1
I like your weights, John. I have a couple hundred but wasn't sure if they might be too much as they weight about 1.2 pounds each.
Best Regards,
AMA 350715
« Reply #22 on: September 18, 2015, 06:25:54 AM »
Bill,
  The weights seem perfect for the job, not to heavy. I bought a bucket full when I was doing a lot of bullet casting. I also have poured some into a cast iron muffin pan (used only for that prurpose) and they weigh about twice as
much 2+/- Lbs. I like using the weights alot better than pins.
AMA 413710
« Reply #23 on: September 18, 2015, 08:52:02 AM »
Bill,
I have the muffin pan ones also, John. Half of our household goods are still in storage until we can buy another house. I have somewhere around 2500# in alloy but the only ones I've seen in the storage unit are the round ones. I'll have to dig deeper. I've been a CBA member for decades but competative shooting has taken a back seat to C/L flying! Time to re-purpose some assets   AP^
Best Regards,
AMA 350715
« Reply #24 on: September 18, 2015, 12:51:35 PM »
I was shooting F-Class last year, not cast though. 180 grn Bergers. Same here I re-purposed my assets into C/L (again!!)
AMA 413710
« Reply #25 on: September 20, 2015, 08:02:46 PM »
Some progress today. Got the elevator covered as well as th fuse and rudder. Gonna try to get the wing covered in the next couple of days.. I may just make it.
AMA 413710
« Reply #26 on: September 20, 2015, 08:03:53 PM »
Pic 2
AMA 413710
« Reply #27 on: September 20, 2015, 08:05:01 PM »
Pic 3
AMA 413710
« Reply #28 on: September 20, 2015, 08:09:21 PM »
Wish I could be there as you could kill two birds with on stone.   Cover stab/elevator and seal the hinge line.  Construction looksgreat.
« Reply #29 on: September 21, 2015, 05:50:47 AM »
Doc,
 I hinged the elevataor with cloth hinges, so I think I'm "covered".... I like to hinge my control surfaces that way, very neat and seals the hinge line. Use Nitrate to stick them on, then tissue over top. You ever use silk over cloth hinges? Next plane I build I want to use Silk.
AMA 413710
« Reply #30 on: September 21, 2015, 04:46:56 PM »
I use cloth hinges under Monokote.   In fact most of my planes have cloth hinges.
John while taking pictures of the plane I decided to do one of the stab/elevator hinge line.
« Last Edit: September 21, 2015, 06:59:14 PM by john e. holliday »
« Reply #31 on: September 22, 2015, 04:54:59 AM »
Man that's nice work!! You will have to share that technique with me Doc!!
AMA 413710
« Reply #32 on: September 23, 2015, 01:42:16 AM »
Last nights progress...
AMA 413710
« Reply #33 on: September 28, 2015, 06:14:16 AM »
Some progress this weekend.. Looking at a Oct 3rd test flight!!
AMA 413710
Offline Dane Martin
  • heli pilot BHOR
« Reply #34 on: September 28, 2015, 07:19:22 AM »
Looking real sweet. You should have no problem finishing it for the fly-a-thon!
« Reply #35 on: September 28, 2015, 07:52:35 AM »
Also built a new handle for the Ringmaster
AMA 413710
« Reply #36 on: September 28, 2015, 07:53:44 AM »
More pics
AMA 413710
« Reply #37 on: September 28, 2015, 08:06:13 AM »
Another pic
AMA 413710
Online Motorman
« Reply #38 on: September 28, 2015, 09:28:12 AM »
What kind of covering is that? Looks like jap tissue.
« Reply #39 on: September 28, 2015, 10:19:51 AM »
Silkspan from Sig i believe. I've had for 17 years or so. Sadly that's the last of it...
AMA 413710
« Reply #40 on: October 01, 2015, 05:20:39 AM »
A couple more pic's after the clear.
AMA 413710
« Reply #41 on: October 01, 2015, 05:35:06 AM »
Also finished the handle... Turned out good I think.
AMA 413710
« Reply #42 on: October 01, 2015, 05:40:50 AM »
Another
AMA 413710
Online Motorman
« Reply #43 on: October 01, 2015, 08:45:52 AM »
Is the dope gonna' be dry enough for Sunday?
« Reply #44 on: October 01, 2015, 11:09:23 AM »
Gonna have to dry enough for Saturday!!
AMA 413710
Online Motorman
« Reply #45 on: October 02, 2015, 01:38:58 PM »
I was secretly racing you, looks like you got yours done first. Mine will be ready for the flyAthon but heavy rain Sat and high winds Sun.
« Reply #46 on: October 02, 2015, 09:46:39 PM »
Same here, hope tonged at least one flight in on Sunday. Was really hoping to have all of my daughters fly this weekend as well as my Father -in-law...dang!!!
AMA 413710
« Reply #47 on: October 02, 2015, 09:48:03 PM »
Any pics Motorman??
AMA 413710
