  • July 16, 2025, 05:18:43 PM
Author Topic: Reporting back on the FS.25 and a wet 2 cycle  (Read 1171 times)
Online Paul Taylor
« on: December 28, 2010, 02:39:11 PM »
OK, I may have the wet 2 setting figured out on my FS .25 on a SkyRay35. All I can say is my old SkyRay never flew that good. It was a little fast but it was a kick in the pants.
I was doing 4.5 sec lap times on 55ft lines, would turn on a dime, and give you 2 cent change.
Did I say it was fun to fly? #^
I think I might try and adjust the line spacing to try and slow the controls down a tad. y1
WoW.... not the same plane that's fer sure.
Re: Reporting back on the FS.25 and a wet 2 cycle
« Reply #1 on: December 28, 2010, 02:55:25 PM »
   First step might be to find some longer lines!  55 feet will screw you into the ground.
   I guess I didn't follow this saga - what is different about your  Skyray from before?
« Reply #2 on: December 28, 2010, 02:56:41 PM »
Brett Beat Me to It!  LOL!!
I was going to say go out to maybe 58' eye to eye.
Online Paul Taylor
« Reply #3 on: December 28, 2010, 03:47:07 PM »
Bret,
I followed your setup, and corrected the controls. Added a CF pushrod.
« Last Edit: December 28, 2010, 04:37:39 PM by Paul Taylor »
« Reply #4 on: December 28, 2010, 03:55:01 PM »
Bret,
I followed you setup, and corrected the controls. Added a CF pushrod.
  And previously, it was set up some other way?
« Reply #5 on: December 28, 2010, 04:05:22 PM »
If the longer lines don't slow it down enough, it will be get a slightly lower pitched prop.
Edit
I'm looking outside and am jealous that you got to fly. Not happening here for awhile.
Online Paul Taylor
« Reply #6 on: December 28, 2010, 04:48:32 PM »
I changed out the elevator. 2 inch cord. Changed out the tank with a uni-flow tank.
Previously I made a extra long control horn because I was not getting enough up. I fixed the control throw and now I went back to a standard horn with equal throw it both directions.
Did I say I liked it?
« Reply #7 on: December 28, 2010, 06:45:35 PM »
Edit
    60 feet should put it just a hair under 5.0 with no other changes.
