  • July 12, 2025, 08:10:51 PM
Author Topic: Reckon This Will Fly?  (Read 2214 times)
« on: December 16, 2010, 12:08:54 PM »
It[Phaeton II] ought to be finished by the end of January ;D
Re: Reckon This Will Fly?
« Reply #1 on: December 16, 2010, 12:38:20 PM »
Should fly just fine. I have been flying the original version R/C for 25 years with an OS 60 open rocker four stroke. I have often thought it would make a good control line fun flyer. What are you going to put in it for and engine? Are you going to throttle it?
« Reply #2 on: December 16, 2010, 01:13:11 PM »
I'm workin on a .60 from an R/C friend of mine....I even thought about a certain .78. I may in fact use a throttle if I get the right engine. ;)
Online Paul Taylor
« Reply #3 on: December 16, 2010, 02:58:14 PM »
That is just too school for cool.
I like all bipes!!!
You need to bring it over to Memphis in the spring for a show and tell!!! y1
« Reply #4 on: December 16, 2010, 03:14:28 PM »
Most things will fly. Love bipes
« Reply #5 on: December 16, 2010, 06:54:40 PM »
Well...I'm goin with a Fox .78 I just won on ebay for $50.........it's a one piece case so it should be fairly light, compared to the older style. But it has a carb....which means I need a venturi or a throttle control. n~
Offline John KruziK
« Reply #6 on: December 16, 2010, 07:30:18 PM »
How big is this plane very cool looking. Post pics when finished
AMA 874027
« Reply #7 on: December 17, 2010, 04:49:48 AM »
Finished length will be 44" from spinner to rudder, the top wing is 48". It's actually an R/C model I'm converting to C/L. Here's a picture of it straddling the back of my couch:
Offline Ward Van Duzer
« Reply #8 on: December 17, 2010, 10:35:11 AM »
John,
A word of caution...Your beautiful curved block Leading edge wing tips will NOT maintain the curve you carved when you apply the covering. The covering will shrink in a straight line from the rib to the sheet part of the tip. If you wish to maintain that curvature you'll need to add some wing tip ribs, or carve a whole block.
Ask me how I know?
Ward-O
Offline Russell Shaffer
« Reply #9 on: December 17, 2010, 10:48:53 AM »
[/q
John, just set the needle or needles where it runs well.  Then adjust the throttle down to the speed you want and lock it there (I use a clevis and threaded rod so it's adjustable. ).  It works well on an LA40.  3 line with throttle would be really neat, though.
Russell Shaffer
Klamath Falls, Oregon
« Reply #10 on: December 17, 2010, 11:55:26 AM »
Hey Ward, thanks for the heads up on the WTs I will correct that before I cover the wings. My plan didn't show clipping the flaps like that. Should I do that too? H^^
« Reply #11 on: December 17, 2010, 11:59:22 AM »
I may do that Russell, kinda waitin to see how big the engine and mount are so I'll know how much room I have. ;D
« Reply #12 on: December 17, 2010, 02:32:12 PM »
it will definitely fly on C/L lines, John. ;D  You might need to have some lead weights ready to strap on your waist (or an engine shut off) in case that Fox .78 cranks on up while it's in the air! LL~ LL~  na# (PE**)
« Reply #13 on: December 17, 2010, 04:03:32 PM »
So you think I need to turn up the castoroil and turn down the nitro......build a venturi with a bigdiameter intake, and muffle down tight! :##
« Reply #14 on: December 17, 2010, 10:41:04 PM »
Actually, Brother john, I would put an itty bitty venturi on it, use FAI (no nitro) fuel and put on a muffler that is so restrictive that it won't hardly let it breathe.  Then it might stay tamed down enough! LL~ LL~
of course, you could use a throttle control!
« Reply #15 on: December 18, 2010, 09:43:19 AM »
John,
The clipped flap is an idea stolen from Randy's SV group of designs. On the outboard wing (that you were looking at) the clipped flap tip is adjustable and becomes a trim tab if required. The IB is fixed.
W.
« Reply #16 on: December 18, 2010, 04:19:19 PM »
John,
W.
Yeah, I gave up on the full flaps...they're gonna be stationary except for a trim tab just like that one. :P
