  • July 14, 2025, 05:13:19 AM
Author Topic: Ready to fly.  (Read 1713 times)
Offline Perry Rose
Ready to fly.
« on: April 13, 2016, 09:00:10 AM »
The Sig Fazer is a dual purpose model. R/C and c/l designed by Mike Pratt. I took his advise and made a few changes and yesterday hosed it down with Krylon and some Rustoleum with the hopes of test flying today. It's raining. I put an OS .40LA with an APC 11 x 4 and a Fox .35 muffler. The landing gear is from a Primary Force. Weight is 49 ounces and the c/g is 4 inches behind the leading edge as the r/c version is 5 inches behind. Monokote on the flying surfaces.
Offline James Holford
Re:
« Reply #1 on: April 13, 2016, 01:37:56 PM »
Looks good perry!!
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Bootlegger
Re: Ready to fly.
« Reply #2 on: April 13, 2016, 01:41:53 PM »
 Shouldn't that Be GEEEZER stunt??
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Perry Rose
Re: Ready to fly.
« Reply #3 on: April 13, 2016, 03:54:41 PM »
It's a long E.
Offline Perry Rose
Re: Ready to fly.
« Reply #4 on: April 13, 2016, 03:56:28 PM »
One more time.
Re: Ready to fly.
« Reply #5 on: April 13, 2016, 05:47:47 PM »
 Nice! y1
 That's about the best looking C/L Fazer I've seen, I like the addition of the wingtips too. What other kind of "changes" did you make?
Offline Perry Rose
Re: Ready to fly.
« Reply #6 on: April 14, 2016, 01:55:38 PM »
I used a set of shortened Primary Force landing gear, The vertical fin/rudder is smaller, the flaps are 1/4 sheet and 2/3 less area, 3/8 nose tripler, tip weight box and leadout slider, Du-Bro pinned hinges and carbon tube push rod. The fuselage has large holes in the rear section and I added another above the wing then sheeted the fuse. with 1/64 ply.
Re: Ready to fly.
« Reply #7 on: April 14, 2016, 06:47:57 PM »
 All good moves I'd say. y1  Any reason you didn't just use the Fazer L/G?
 I've had a Fazer wing kit on my shelf for years, this one kind of gets me thinking about it again... ;D
Offline Perry Rose
Re: Ready to fly.
« Reply #8 on: April 15, 2016, 05:13:46 AM »
The Fazer gear is larger and heavier.
