  • July 13, 2025, 09:20:31 PM
Author Topic: Aluminum from a frame shop  (Read 935 times)
Offline Charles Carter
  • Flying Control Line Stunt
« on: January 24, 2013, 03:47:55 PM »
I have a big quantity of aluminum framing  for pictures and art from a frame shop. I have straight pieces as well as right angle pieces.  I am considering scraping it for cash.  I am wondering if anybody has used this stuff for modeling purposes? I thought it could be useful for a wing or fuselage jig.  Any suggestions on how I could use it in modeling?
Charles Carter
  • Gravitywell
Re: Aluminum from a frame shop
« Reply #1 on: January 24, 2013, 06:07:24 PM »
What sizes do you have?
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Bob Hudak
« Reply #2 on: January 24, 2013, 07:23:47 PM »
Charles,
 I would hang on to a couple feet of the right angle aluminum. I t can be used to mount an electric motor to a profile or full body plane.
 Bob
350838
« Reply #3 on: January 24, 2013, 07:24:24 PM »
Fixturing sound like a good use.  Due to the low grade alloy in such applications, I wouldn't use it in the actual product.
« Reply #4 on: January 24, 2013, 07:28:38 PM »
I would use it to frame a picture of photogenic persons such as the Jive Combat Team.
Offline Matthew Cosier
« Reply #5 on: January 24, 2013, 09:05:07 PM »
 You can make some good sanding tools with different types of alloy extrusions, the 90degree ones are good for many sanding jobs, just glue the sanding paper on.
« Reply #6 on: January 25, 2013, 10:01:53 AM »
Regarding sizes its varies from lengths as short as 4" to 44".  I have all the remaining stock from a frame shop that went out of business.  Thank you for all your comments.
Charles Carter
« Reply #7 on: January 25, 2013, 10:12:32 AM »
Charles, could you post a picture showing the cross section(s) and maybe lay a ruler beside to relate approximate size? Seems you may have a ready market here!
