  • July 10, 2025, 04:41:05 PM
Author Topic: ??? Suggestions ???  (Read 1277 times)
Offline Bootlegger
??? Suggestions ???
« on: February 21, 2008, 08:18:35 AM »
    :!   Guy's when you are making fillets with epoxy (micro baloons) and such and you have the borders taped off how long do you let the mixture cure before you remove the tape, and smoothe out your fillets?
  Also do you use a "bare" finger or do you use gloves (nitrile or latex)???
         Thanks for your suggestions,
        "U S Veterans have earned their stripes"...
      Gil Proud 8th Air Force veteran...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: ??? Suggestions ???
« Reply #1 on: February 21, 2008, 09:54:55 AM »
I pull the tape before the fillet is set, actually as soon as I have finished everything but the final finger operation. The tape leaves a little ridge which gets smoothed out with a finger dipped in rubbing alcohol. I use a bare finger and cheap rubbing alcohol because the mixture of alcohol and water seems to work better than either one alone. By the time I have the tools cleaned up and the tape removed it's usually ready for the finger.
Can't imagine using a glove, seems to me it would get in the way unless it was a very tight fit on the finger with no little flappies.. Not sure what they are called but the little finger condoms might be a better deal.
Offline Peter Ferguson
« Reply #2 on: February 21, 2008, 12:06:01 PM »
They call them finger cots. I gave my son a box of them when he turned 16 and I gave him "the talk" You  should have seen the look on his face.
Peter Ferguson
Auburn, WA
Offline Bootlegger
« Reply #3 on: February 21, 2008, 04:00:23 PM »
      #^  Thanks guy's,  Yes they are called finger cots, and they work  GREAT as Tony would say...      Thanks again...
Gil Causey
AMA# 6964
« Reply #4 on: February 21, 2008, 09:56:45 PM »
Pete...You had me ROFLMAO  LL~ with that story. I'm SO glad you're a NW Skyraider!  H^^ Steve
Offline Keith Spriggs
    • khspriggs
« Reply #5 on: February 23, 2008, 02:10:36 PM »
That sounds like something I might have done for my son ,if I had thought of it.
Offline Leo Mehl
« Reply #6 on: February 23, 2008, 02:39:22 PM »
He probably should have given you the same disertation! LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ VD~ HB~>
