  • July 18, 2025, 01:59:40 PM
Author Topic: push rod ends  (Read 901 times)
Offline peabody
push rod ends
« on: February 07, 2017, 12:22:11 PM »
Not to steal Mike's great video about joining pushrods, I have a couple of thoughts....
#1 Why not use aluminum tube? It's lighter and, essentially, just serves to contain the J B Weld.......
#2 Why not use a shorter piece of tube to seal the end of the pushrod to prevent splitting?
Have fun!
Online Perry Rose
Re: push rod ends
« Reply #1 on: February 07, 2017, 12:31:54 PM »
And drill a tiny hole to make it easier to force the JB Weld inside and keep the pressure build up from pushing the insert out of position.
Offline Allan Perret
  • Proverbs
Re: push rod ends
« Reply #2 on: February 07, 2017, 03:22:38 PM »
The pressure is minimal, I use rubber bands to keep fitting in place till epoxy sets.  Don't like the idea of drilling hole in cf tube.
I also have been using short piece of alum tube at ends instead of wrapping to prevent splitting.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Mike Griffin
Re: push rod ends
« Reply #3 on: February 07, 2017, 05:51:02 PM »
Have fun!
You certainly could Rich.  I just happened to have some 1/4" brass tubing here in the shop but aluminum would work as well.  As far as the push rod ends, I really like the threaded type that Eric Rule is selling now that capture the outside of the rod in a cup to prevent  splintering.  That goes to Allan's point plus gives you the threads for the ball link.
