Hello Chuck,
Sounds as if the rechargeable batteries have finally died. I assume it is a battery version and not mains powered. I do not have that model, but a determined man should be able to remove the batteries and replace with similar ones.
I have changed the batteries on many rechargeable tools. Most of them are sub C, but I suspect your batteries are AA. So that should be a cheap and easy substitution. 18 Volt drills are very expensive to put new batteries in. What I usually do in this case, is to look out for similar battery packs being sold off cheap for end of line drills. I have managed to buy quite a few of these and snap them up when I see them. You then have to do a desoldering / soldering routine because the battery layout is always different!
Best of luck,
Andrew.
P.S. I do know the difference between batteries and cells, but use the common (incorrect) usage!
