  • July 09, 2025, 05:15:51 AM
Author Topic: Pull Test? How does your club handle this task?  (Read 2051 times)
Offline frank mccune
« on: March 23, 2015, 06:47:59 AM »
     Hello All:
     As Safety Officer of our club, I am attempting to formulate a method to perform a pull test when we fly our airplanes.
     The most simple way to do this is to use the formula of pulling ten times the model's weight on all of the control elements.
     Any suggestions as to how to do this?
                                                              Tia,
                                                              Frank McCune
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Pull Test? How does your club handle this task?
« Reply #1 on: March 23, 2015, 07:59:31 AM »
Well if you want the most sophisticated pull test machine in existence you can build one like we use in Tulsa. Just need someone that can weld and do a little machine work. We built 3 just so we would have one available for each pit area. Operation is as simple as it gets, pit boss straps the handle into the leather holder, asks the pilot what his airplane weighs, sets the counter weight to the airplanes weight and pilot pulls till the flag drops.
http://www.somethinxtra.com/Public/PullTestMachine.pdf
Offline bruce finley
« Reply #2 on: March 23, 2015, 11:13:43 AM »
That is so cool bob
« Reply #3 on: March 23, 2015, 05:31:44 PM »
Fish scale.
Offline Andre Ming
« Reply #4 on: March 24, 2015, 04:45:12 AM »
Re: Tulsa Gluedobbers' Pull Test Stands...
They are SOOOO easy to use and SOOOO cool and sophisticated.
Even a moron from eastern OK can do it.  LL~
« Reply #5 on: March 24, 2015, 12:53:45 PM »
If the club could put price on them, they might sell a few.   I don't have the equipment or skills to make one.
« Reply #6 on: March 24, 2015, 01:01:03 PM »
Calibration?
« Reply #7 on: March 24, 2015, 01:59:20 PM »
Calibration?
THIS IS A GUESS:
If the scale is placed so that the center of mass of the slider is 6.4" from the pivot when the pointer is at 17lb, then calibration should consist of pulling some test weights with a scale, and adjusting the weight of the "approximately 30 pounts" weight until things work right.
No one specifies an accuracy for pull testing: In my opinion if you're within a pound you're probably OK, but if you want to be picky you can make sure that all of the weights are "at least", and marginal planes need not apply.
Offline Bob Reeves
« Reply #8 on: March 24, 2015, 02:29:16 PM »
Actually it's all pretty simple math once you know how much the weight weighs and know the ratio of the moment arms. A whole lot more accurate than a spring fish scale with someone trying to react at the exact microsecond the scale reaches the desired reading.
It is impossible to over pull an airplane with our machines, once the weight has been lifted off rest the amount of pull will actually decrease.
The only down side is the complexity and effort they take to build.
« Reply #9 on: March 25, 2015, 04:06:30 PM »
NW Skyraiders have settled on using Bow Scales (Cabela's). More portable, easy to adapt, easy to use with the pre-set arrow. We had one of the first of the "pull test machines", but it was a PITA to store and transport. The bow scales hang in our shed at the airport and don't take up much of any space. We could build one like Bob's, but there's no need or inclination.   H^^ Steve
« Reply #10 on: March 25, 2015, 04:37:04 PM »
Erm -- read the AMA Safety Code, which certainly ought to be the controlling document for a Safety Officer at an AMA sanctioned club?
D. CONTROL LINE
1. The complete control system (including the safety thong where applicable) must have an inspection and pull test prior to flying.
2. The pull test will be in accordance with the current Competition Regulations for the applicable model aircraft category.
3. Model aircraft not fitting a specific category shall use those pull-test requirements as indicated for Control Line Precision Aerobatics.
Short, simple, to the point, and it keeps a speed model from being pull tested at far below what it would be in competition.
« Reply #11 on: March 25, 2015, 05:16:04 PM »
While Tim is correct, he's also assuming that Mr. McCune is somewhere in the USA, and we really don't know that. It doesn't really hurt anything to put that in your profile. Come to think of it, we're assuming that Tim lives someplace or other.  VD~ Steve
« Reply #12 on: March 25, 2015, 08:41:15 PM »
I have my location in my profile.  I'm right here!
« Reply #13 on: March 25, 2015, 08:49:01 PM »
OK, "Right Here" is a bit misleading.  So, is it better now?
