  • June 16, 2025, 09:03:02 PM
Author Topic: 09 cox fuel  (Read 458 times)
Offline Bootlegger
09 cox fuel
« on: July 30, 2020, 07:43:05 AM »
 What is a good fuel for Cox 09 Medallion engine, and where can I get it?  Obliged...
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Dan Berry
Re: 09 cox fuel
« Reply #1 on: July 30, 2020, 07:48:15 AM »
Use the same as you would in a 1/2A from COX.
15-25% pop and 20-225% all castor oil.
Offline kenneth cook
Re: 09 cox fuel
« Reply #2 on: July 30, 2020, 02:03:59 PM »
            There's little to no parts support for the .09. Running nitro above 20% really can taxi your glowhead.  Plugs are even hard to come by. Yes, adapter plugs for standard longs work but not like the Cox glowhead does. You give up a lot of rpm's using adapter heads. I don't own the Medallion .09. I own the TD .09's. I run all of my Medallions including .049's on Powermaster GMA 10% nitro fuel and they run just fine with no needling issues.  I personally don't use all castor because these engines like to varnish up rather quickly and hotter weather brings it on quicker. Sig Champion is 20% total oil 50/50 synthetic just like the Powermaster.
Offline Bootlegger
Re: 09 cox fuel
« Reply #3 on: August 01, 2020, 04:01:36 PM »
 Mr Cook, do I understand that you suggest using powermaster 10-22 fuel?  I'm obliged
Gil Causey
AMA# 6964
