Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 07, 2025, 07:15:41 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
...props...
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ...props... (Read 1925 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
...props...
on:
October 29, 2013, 12:14:58 PM »
Been running a 12.25x3.75 on my OS LA 46 I sure could use more "drive".
Seems that I read that someone had reduced the dia on these props by 1/2", has anybody got some suggestions?
I'm not sure about the RPM range on this engine, but due to tank capacity being less than 4 ounces, I'm running only 2.5 % nitro and have about 6-8 laps at the end of the pattern..
Suggestions sure would be helpful...
Thanks a lot...
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Re: ...props...
Reply #1 on:
October 29, 2013, 01:39:49 PM »
Gil, try the APC 11.5 x 4 and 11 x4. You' ll get more punch. Try about 9400 rpm or a solid but rich two cycle and forget the 2-4 break. These engines are designed originally to be RC engines and don't know what the FoxCrack is.
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: ...props...
Reply #2 on:
October 29, 2013, 06:55:20 PM »
Look in the Engine Setup forum that Randy Smith moderates. At the top, you'll find a pinned subject that is .46LA specific, so you should find a lot of options there. Remember that less prop load will increase your run time and allow you to run more nitro.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
N-756355
AMA Member
Trade Count:
0
Admiral
Re: ...props...
Reply #3 on:
October 29, 2013, 06:59:36 PM »
I'm running a Majic 12.25-4.25 two blade and have not had any issues in the Florida air. I'm also getting a beautiful 4-2 break at 9300-9400 launch RPM.
Logged
Andrew Saunders
Trade Count:
0
Commander
2013 Nats
Re: ...props...
Reply #4 on:
October 29, 2013, 07:08:40 PM »
I use a master airscrew 11x4. Also an apc 11x4 and get plenty of power.
Logged
Garf
Trade Count:
0
Admiral
Re: ...props...
Reply #5 on:
October 29, 2013, 09:26:41 PM »
I am using an XOAR 12 X 4 using 3 oz for the pattern. This is with Sig 5% nitro, 20% 50/50 oil.
Logged
"SAVE ALL THE PIECES"-Phil Brown
http://hangarflying.proboards.com/index.cgi?board=wire
bob whitney
Trade Count:
0
Admiral
Re: ...props...
Reply #6 on:
October 29, 2013, 09:33:05 PM »
email me at f2cracer@aol.com i have a prop that works very good on the 46 Bob
Logged
rad racer
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: ...props...
Reply #7 on:
October 30, 2013, 12:54:00 PM »
Bob W, I sent ya' an e mail titled props.......
Logged
Gil Causey
AMA# 6964
Will Davis
25 supporter
Trade Count:
0
Admiral
Re: ...props...
Reply #8 on:
November 01, 2013, 07:28:43 PM »
Bob makes some nice props, been using his for several years, he has a very good 13 6 prop for the st 60 ,
For a mass produced prop , I would try the APC 12/4 , great prop , reasonable priced, very consistent in pitch from one prop to the other
Logged
Will Davis
"Carolina Gang"
Scott Richlen
AMA Member
Trade Count:
0
Admiral
Re: ...props...
Reply #9 on:
November 02, 2013, 05:42:42 PM »
I am running a Zinger Pro 12-4 on the LA-46 in my Fun-51. Dick Houser set up the engine for me. Uses 5 and 3/8ths ounces of 5% to get through the pattern. I am very happy with this prop.
Scott
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
...props...
