  • July 08, 2025, 12:26:19 AM
Author Topic: ...props...  (Read 1933 times)
Offline Bootlegger
...props...
« on: October 29, 2013, 12:14:58 PM »
 Been running a 12.25x3.75 on my OS LA 46 I sure could use more "drive".
 Seems that I read that someone had reduced the dia on these props by 1/2", has anybody got some suggestions?
 I'm not sure about the RPM range on this engine, but due to tank capacity being less than 4 ounces, I'm running only 2.5 % nitro and have about 6-8 laps at the end of the pattern..
  Suggestions sure would be helpful...
     Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ...props...
« Reply #1 on: October 29, 2013, 01:39:49 PM »
Gil, try the APC 11.5 x 4 and 11 x4.  You' ll get more punch.  Try about 9400 rpm or a solid but rich two cycle and forget the 2-4 break.  These engines are designed originally to be RC engines and don't know what the FoxCrack is.
Online Steve Helmick
Re: ...props...
« Reply #2 on: October 29, 2013, 06:55:20 PM »
Look in the Engine Setup forum that Randy Smith moderates. At the top, you'll find a pinned subject that is .46LA specific, so you should find a lot of options there. Remember that less prop load will increase your run time and allow you to run more nitro.  @@^ Steve
Offline Matt Colan
Re: ...props...
« Reply #3 on: October 29, 2013, 06:59:36 PM »
I'm running a Majic 12.25-4.25 two blade and have not had any issues in the Florida air. I'm also getting a beautiful 4-2 break at 9300-9400 launch RPM.
Offline Andrew Saunders
  • 2013 Nats
Re: ...props...
« Reply #4 on: October 29, 2013, 07:08:40 PM »
I use a master airscrew 11x4. Also an apc 11x4 and get plenty of power.
Offline Garf
    • Hangar Flying
Re: ...props...
« Reply #5 on: October 29, 2013, 09:26:41 PM »
I am using an XOAR 12 X 4 using 3 oz for the pattern. This is with Sig 5% nitro, 20% 50/50 oil.
Offline bob whitney
Re: ...props...
« Reply #6 on: October 29, 2013, 09:33:05 PM »
email me at f2cracer@aol.com  i have a prop that works very good on the 46  Bob
rad racer
Offline Bootlegger
Re: ...props...
« Reply #7 on: October 30, 2013, 12:54:00 PM »
 Bob W, I sent ya' an e mail titled props.......
Gil Causey
AMA# 6964
Offline Will Davis
Re: ...props...
« Reply #8 on: November 01, 2013, 07:28:43 PM »
Bob makes some nice props, been using his for several years, he has a very good  13 6 prop for the st 60 ,
 For a mass produced prop ,  I would  try the APC 12/4 , great prop , reasonable priced, very consistent in pitch from one prop to the other
Will Davis
"Carolina Gang"
Re: ...props...
« Reply #9 on: November 02, 2013, 05:42:42 PM »
I am running a Zinger Pro 12-4 on the LA-46 in my Fun-51.  Dick Houser set up the engine for me.  Uses 5 and 3/8ths ounces of 5% to get through the pattern.  I am very happy with this prop.
Scott
