  • July 11, 2025, 01:12:25 PM
Author Topic: problem with s.t to fox  (Read 1528 times)
Offline W.D. Roland
« on: August 11, 2006, 11:48:16 AM »
this may be a dumb question but needs solving before new stunter can fly.
the airplane was built to use a s.t. .35 stunt with a fox prop shaft extension and a fox aluminum spinner.
problem is that the s.t. threads are m.m. and extension nut is sae.
anyone know where i can find a adapter nut that is proper m.m. thread on engine end and sae on spiner end?
  David
David Roland
51336
Re: problem with s.t to fox
« Reply #1 on: August 11, 2006, 12:27:31 PM »
All my ST motors incliding my .35 are SAE
Offline peabody
« Reply #2 on: August 11, 2006, 12:39:35 PM »
Randy Smith would be my choice...
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: August 11, 2006, 02:56:16 PM »
I have several ST 35's and 46's, they are all 1/4 28.. You sure the shaft isn't buggered up or maybe your prop extension is the wrong thread.
Offline W.D. Roland
« Reply #4 on: August 12, 2006, 12:57:02 AM »
thanks guys! for making me go pay atention and check things.
it realy baffeled me when first trying to fit it up as i never had problems that i remembered.
find that 30 year old memories cant be depended on.
what i found--dug out a few foxes k&b o.s. & s.t.
extension nut fit all but s.t.!  n~
stock nuts fit all engines  n~ n~
measured all shaft threads and all are 1/4-20!  n~ n~ n~
ran a tap through extension and it removed enough metal to have been cutting threads in a blank hole!(tap drill size )  %^
now it fits all engines!  #^
agin--thanks and ill try to pay attention next time !  :!
David
David Roland
51336
Offline W.D. Roland
« Reply #5 on: August 12, 2006, 12:59:34 AM »
that should read 1/4-28  :P
David Roland
51336
