  • July 07, 2025, 01:59:16 AM
Author Topic: Printed motor mount.  (Read 1153 times)
Offline Perry Rose
« on: September 22, 2021, 02:50:06 PM »
What glue is best for attaching the printed electric motor mount to balsa and plywood?
Offline Steve Berry
Re: Printed motor mount.
« Reply #1 on: September 22, 2021, 03:09:59 PM »
I would use 10 minute epoxy. Even 5 minute would work well.
Sent from my SM-N986U using Tapatalk
Offline Jim Hoffman
« Reply #2 on: September 22, 2021, 03:32:06 PM »
I used Slow Epoxy (Zap 30-minute Z-Poxy) to bond the 3-D printed motor mount from Okie Air (formerly Tom Morris) to maple.  I also put shallow notches with a jigsaw into the maple surface to give some added mechanical bite.  The faster epoxies are more brittle and less strong, I don’t use them anywhere strength is needed.  70 flights to date, no issues
Offline Perry Rose
« Reply #3 on: September 22, 2021, 03:51:12 PM »
Thanks for the replies.
Offline Paul Wescott
« Reply #4 on: September 23, 2021, 12:38:47 AM »
…The faster epoxies are more brittle and less strong, I don’t use them anywhere strength is needed.
Jim - I’ve always found 5-min epoxy to be the opposite of brittle.  It always turns out rubbery and/or flexible when cured, which is why I stopped using it.  Can you please expand on “brittle”?
Paul W.
Offline Jim Hoffman
« Reply #5 on: September 23, 2021, 09:54:46 AM »
Paul W.
Paul you are right.  I had not used 5-minute epoxy in so many years I forgot.  I just mixed up some 5-minute Zap epoxy.  An hour later I could bend the puddle without cracking.
« Reply #6 on: September 23, 2021, 10:12:25 AM »
I drill 4 holes (1/8" or so through the mount.  Two on top, two on bottom and plug them with a wooden dowel.  That puppy isn't going anywhere.  You can do the same for a full body but I don't use these for full body opting instead for the "through the firewall" design.
ken
