  • July 08, 2025, 01:54:22 AM
Author Topic: primer over dope  (Read 843 times)
Offline Lester Nicholson
primer over dope
« on: August 05, 2014, 06:56:47 AM »
I have an airplane covered w/silkspan with four coats of clear sig dope [lite-coat]. It has set now for six weeks. Can I use Rustoleum auto primer on it?  Thanks for any advice.  I would like to use rustoleum paint if I can.   Nick
Offline Phil Krankowski
Re: primer over dope
« Reply #1 on: August 05, 2014, 07:01:42 AM »
I have used Rustoleum grey  primer over old dope finishes.  The dope was years old and I have had no problems.  I have not tried over relatively fresh finishes, but I expect 6 weeks is probably log enough for the dope to finish gassing off.
I would do a small test spot somewhere that can be easily sanded away.  The primer will fish-eye or orange peel if there is a real problem.
Phil
Offline George
  • Love people, Use things.
« Reply #2 on: August 05, 2014, 09:19:03 AM »
Lester, You might consider using Nitrate clear next time. It gasses off much quicker.
George
George Bain
AMA 23454
« Reply #3 on: August 05, 2014, 09:30:40 AM »
I've used Robert's 540 primer over dope. The next day! Never had a problem with gas out, bubbles or lifting.
I doped yesterday and will prim today.  ;D
Keep in mind, I scratch everything before applying another coat.
I also do a masking tape, pull, test.
« Reply #4 on: August 05, 2014, 11:55:03 AM »
Thank you gentlemen. Fix'n to prime. Again, thanks - you have been very helpful with this old mans decision making.  Nick
