  • June 28, 2025, 04:18:19 AM
Author Topic: Power tools  (Read 2374 times)
Offline redout
Power tools
« on: June 30, 2022, 06:48:23 PM »
Hi all.
With a renewed interest in this hobby, and having been in preparation for it for some time, I feel I am on the verge of substantially increasing the time I spend building. I have completed only one proper kit so far, a Sig Banshee. Over the past couple of years, I have accumulated many small hand tools in anticipation of their usefulness e.g. various hand saws, wire bending equipment, drill bits, rasps, squares, etc.
Is there any power tool that experienced builders' feel is very worthwhile obtaining, besides what I have already, being a hand drill, a drill press, dremel and jig-saw.
I have some space problems so would prefer not to add another item if the above are judged to be enough. But if there is that item that is felt to be "indispensable", I would try to obtain it.
For information, I won't be scratch building at this time - only kit building - both profiles and full-fuselage models.
Richard.
Re: Power tools
« Reply #1 on: June 30, 2022, 06:51:53 PM »
Big belt-disk sander
Offline Dan Berry
Re: Power tools
« Reply #2 on: June 30, 2022, 06:59:46 PM »
Jigsaw
Do you mean a bench top tool or what a lot of us old guys call a saber saw?
If you have a saber saw I would recommend a scroll saw.
Elsewise the disc sander.
Re: Power tools
« Reply #3 on: June 30, 2022, 07:10:33 PM »
 A solder gun comes in handy if you're going to make tanks. A 3" PSA sanding disk is good to have for your drill motor.
Motorman 8)
Offline Dennis Nunes
Re: Power tools
« Reply #4 on: June 30, 2022, 07:30:09 PM »
Indispensable Tools (Listed by Most Used):
1. 4"x36" Belt/6" Disk Sander
2. 5-Speed Bench Top Drill Press
3. 16" Variable Speed Scroll Saw
4. 9" Bench Top Band Saw
5. 1"x30" Belt Sander
6. 16" Scroll Saw
7. 10 Gal. Oil Lubricated Air Compressor
8. 7" Table Saw
I couldn't settle for just one as my favorite or most indispensable. I can't live without any of them. All the tools are from Harbor Freight with exception of the 30 year old B&D 7" Table Saw.
Strangely, when I was a kid I didn't have any of these tools to build with, only hand tools.
Dennis
Re: Power tools
« Reply #5 on: June 30, 2022, 11:23:26 PM »
In priority order (for me):
1. Drill press with variable speeds, and with at least fractions and number drill index (or metric equivalent)
2. Dremel, variable speed
3. MonoKote Heat gun
4. MonoKote ir on (to replace the clothes iron and keep the peace….)
5. Soldering iron
6. Bandsaw (or as a lesser substitute, a scroll saw)
7. Stationary sander (the vertical belt sanders with wide belt are so much nicer than the others…and adding the disk is helpful.)
8. Compressor for painting
9. Pedestal or benchtop grinder if you are going to be making controls
10. Vacuum pump, if you are going to do much composite work
If you never plan on using plastic finishes, drop out #4, but #3 still has a bunch of other uses.
There are always more tools you will want, but for making models, you likely would rarely need them. But, people develop their work techniques around what they have, so there are always advocates of one tool/technique or another.
Offline redout
Re: Power tools
« Reply #6 on: July 01, 2022, 05:49:21 AM »
Jigsaw
Dan, this is what I have always called a jigsaw. It came in handy the other day for cutting out the 1.0 mm thick plywood doublers for the electric Banshee ( using a finer blade than shown in the photo ).
Offline redout
Re: Power tools
« Reply #7 on: July 01, 2022, 06:12:36 AM »
Thanks to everyone for those suggestions. I did realise afterwards I do have the heat gun for Monokote type coverings and I also have some soldering irons ( largest 80 W ).
I notice that several people mentioned belt sanders, disc sanders, scroll saws and band saws.
Forgive the rookie questions but are these power tools mainly used on non-balsa woods ?
And if the sanders are used on balsa, doesn't the abrasive material get clogged with the soft wood ?
Offline Dan Berry
Re: Power tools
« Reply #8 on: July 01, 2022, 06:48:22 AM »
Yup. I grew up calling that a saber saw.
For your next tool I would recommend a scroll saw.  Or a small bench top band saw.  In that order.
Offline Leonard Bourel
Re: Power tools
« Reply #9 on: July 01, 2022, 07:37:24 AM »
Yes I agree with Dan The scroll saw is your best friend in this hobby My parents bought me my first one when I was 16 and just 1 year into the hobby It died when I was 48 I bought a new one then and it only lasted 5 years I bought another new one and it only lasted 6 years I then inherited one from a close modeling friend who passed It is a little beast I think it will last for a long time
Re: Power tools
« Reply #10 on: July 01, 2022, 08:14:52 AM »
I know that the subject of this thread is "Power Tools", but these are also tools powered by a person and are the first on the list of tools that are indispensable on your workbench:
1.   Xacto knives with assorted blades including an unlimited supply of No. 11 blades
2.  Sandpaper blocks in assorted shapes and lengths with sheets of sandpaper of various grits from 60 or 80 to 600
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Power tools
« Reply #11 on: July 01, 2022, 12:30:52 PM »
two good soldering systems, one for larger stuff, a temperature-controlled one for electronics, and soldering wires.
good pair of fishing crimpers
Dave Siegler
NE9N extra class
AMA 720731
Offline Steve Dwyer
Re: Power tools
« Reply #13 on: July 01, 2022, 07:19:18 PM »
A down draft sanding bench attached to your shop vacuum, especially important if you get complaints of dust reaching the living area.
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Power tools
« Reply #14 on: July 02, 2022, 06:12:56 AM »
Hello
Surprised no one mentioned a small 4" angle grinder as I always have a few in the modelling room, set up with a grinding wheel, cut off wheel and flapper disc to deal with alloy, steel and carbon fiber. With a flapper disc you can hollow out or rough shape a model in minutes before using a sanding block. My favorite tool is a 'hunting knife' my grandmother gave me when I was 6 years old that has shaped many leading edges and mixed tons of epoxy in the 50 years I've used it.
Regards Gerald
Offline Steve Dwyer
Re: Power tools
« Reply #15 on: July 02, 2022, 07:21:45 AM »
Hello
Regards Gerald
Gerry,
Sounds like a gouging blade in the Xacto set.
Offline Gary Dowler
Re: Power tools
« Reply #17 on: July 03, 2022, 12:03:48 AM »
Paul Walker turned me on to one of the most useful tools you will ever have. Its a real game changer. Get yourself a Micro Mark mini table saw. Extremely useful tool, and at only a little over a foot square, it doesnt take up too much space.  Its got every feature a full size saw has, tilt, blade height, extended table, etc, and its extremely well made.  You can even get Dado blades for it, taper jigs as well as a host of other things.
You wont regret the purchase.
Gary
Re: Power tools
« Reply #18 on: July 03, 2022, 03:20:33 PM »
Gerry,
Hi Steve
The Flapper Disc on a light, small angle grinder may sound like one step down from a chainsaw but with the right grit disc and a bit of skill is an amazing tool. Ideal for trimming off epoxy , ply and hardwood where a normal sander would only round things and with a 120 grit disc on balsa and a careful hand its so fast shaping block , you just need a good dust mask or better till a full spray mask.
Regards Gerald
Offline Jim Hoffman
Re: Power tools
« Reply #19 on: July 03, 2022, 04:25:13 PM »
Gary
They sell two models. I purchased the one with a tiltable blade.  I agree, it's a fabulous tool.  But one needs a jigsaw first.
https://www.micromark.com/MicroLux-Mini-Tilt-Arbor-Table-Saw-for-Benchtop-Hobby-Use_2?msclkid=d6cc8e780dc215a64e36ecba1bb15a66&utm_source=bing&utm_medium=cpc&utm_campaign=NX_NTM_Shopping_Holiday%20Season_Top%20SKU%27s&utm_term=4575755084599696&utm_content=Holiday%20Season_Top%20SKU%27s
Offline redout
Re: Power tools
« Reply #20 on: July 03, 2022, 04:37:35 PM »
Looking through all the suggestions ( apologies if I have missed anyone's - it's early here and the coffee hasn't kicked in yet... )
I have soldering equipment (including for electronics), a variable speed bench drill, air compressor, Dremel, fishing swage crimpers, heat gun, pedestal grinder, 4 inch angle grinder, table vise (in Australia, we actually spell the tool as vice), Xacto knives (thanks for No. 11 blade suggestion - was wondering), sanding blocks, dust and spray masks.
I do not have belt or disc sanders, scroll or band saws, table saw, vacuum pump, down draft sanding bench with vacuum or that mini table saw, nor a metal lathe ( that one will have to wait a while !  :) )
By consensus, I think the scroll saw came up most  and that's what I will look at now. But I also have a long list of other tools suggested and no doubt their usefulness will become apparent to me in the coming months.
Thanks for all the help !
Offline redout
Offline Gary Dowler
Re: Power tools
« Reply #22 on: July 03, 2022, 07:22:46 PM »
That does look nice !
Buy one and you'll never regret the purchase.
Gary
Offline BillP
Re: Power tools
« Reply #23 on: July 16, 2022, 09:22:50 AM »
I mostly scratch build and have most of the tools posted except the micromark table saw. The least used is an electric scroll saw and electric sabre saw. They are too tedious to keep a smooth contour for me. I'd spend the money on a bench belt sander with disc and/or small band saw.
Aluminum jig for cutting accurate angles with wide blade xacto saws
Hand tool for ripping sticks or narrowing sheets..I think mine was made by MasterAirscrew and uses #11 bade.
Miniture planes...razor blade and standard blade types.
Long drill bits glued into ends of long dowels. Lets you hand drill into small places like firewalls.
Wood dowels with sandpaper glued for hollowing lead holes and such.
Outside calipers for measuring solid block carving thickness...I can't remember the name of this tool but I use it on tank lids and engine cowls.
Bill P.
