  • July 29, 2025, 12:09:10 AM
Author Topic: Portable runway?  (Read 1620 times)
Offline Kirk_Binns
Portable runway?
« on: August 04, 2008, 08:32:16 AM »
I fly at a park where the city generally is in arrears with its lawn-mowing responsibility.  Any hints on a rollup runway that I could lay down in front of my plywood mounted stooge?  And fit into a mid-size sedan?
Offline RC Storick
Re: Portable runway?
« Reply #1 on: August 04, 2008, 08:55:30 AM »
Weed eater. Just weed eat out a runway.
Online Crist Rigotti
« Reply #2 on: August 04, 2008, 10:29:55 AM »
I use 4 pieces of 10mm Coroplast.  Each piece is cut into a bit of a wedge.  the doms are approx. 42 x 24.  The inner edge is about 1 inch shorter than the outer edge so when laid down it forms a bit of an arc.  I attached my stooge to the first piece and shingle the rest.
Offline Ryan Cooper
« Reply #3 on: August 04, 2008, 12:35:22 PM »
Check out the sporting goods section at WalMart. They have these nice black rubber matts that snap togather, the ones like they use to put weight stuff on in a gym.
Offline Ralph Wenzel (d)
« Reply #4 on: August 04, 2008, 01:12:39 PM »
Carpet remnants work well. Roll 'em up when you're done. When they get too grungy, pitch 'em and get more.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #5 on: August 04, 2008, 02:35:55 PM »
Old asphalt shingles work pretty well also. They are generally heavy enough to smash the grass down.
« Reply #6 on: August 04, 2008, 04:12:06 PM »
You might want to check with some places that use conveyors. We got a few old belts and they make great runways. The only thing is they will brown the grass after a hot day of flying.
These are about 3 ft wide.
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #7 on: August 04, 2008, 04:38:03 PM »
Asphalt shingles will KILL the grass on a warm day. HB~> I work construction I have had much experience.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Gary Anderson
« Reply #8 on: August 04, 2008, 04:41:51 PM »
HI guys,
 I just use one of the old kids slip and slides, they don't cost much and they come with pins and the works. Have fun Gary
Gary Anderson
Offline Russell Shaffer
« Reply #9 on: August 04, 2008, 09:32:19 PM »
They call them carpet Runners.  Not very expensive and they come in about three foot widths.  Check the Marts, Kmart, Walmart, etc.
Russell Shaffer
Klamath Falls, Oregon
