  • July 06, 2025, 02:56:06 PM
Author Topic: Plane transport  (Read 1614 times)
Online James Mills
Plane transport
« on: May 04, 2021, 06:27:37 PM »
I am in the process of replacing my Tahoe, planning to get either a Suburban/GMC or Ford Expedition Max for the extra room.  Unfortunately all the dealerships in our are are thin on numbers.  We'll make the trip again this year in either the Tahoe or my wifes Flex and with 3 of us in the cabin packing multiple planes for Ben and I gets tight.  I'm thinking about either renting or purchasing a trailer for the planes.  Any suggestions?
AMA 491167
Offline Crist Rigotti
Re: Plane transport
« Reply #1 on: May 04, 2021, 08:01:13 PM »
Put the planes in the car, and Ben in the trailer!
Online James Mills
Re: Plane transport
« Reply #2 on: May 04, 2021, 10:12:15 PM »
Beth and I already talked about that as a plan  y1
AMA 491167
Re: Plane transport
« Reply #3 on: May 05, 2021, 07:13:47 AM »
 y1 y1 y1 y1 y1
Offline BillP
Re: Plane transport
« Reply #4 on: May 05, 2021, 07:33:36 AM »
For a single trip or two I'd rent a small enclosed U Haul trailer. No worry, no hassles.
Bill P.
Offline John Rist
Re: Plane transport
« Reply #5 on: May 05, 2021, 08:23:19 AM »
How about a roof top carrier ?
https://www.amazon.com/adakiit-Carrier-Storage-Waterproof-Resistant/dp/B07KYKRBZ3/ref=sr_1_4?_encoding=UTF8&c=ts&dchild=1&keywords=Vehicle+Hard-Shell+Carriers&qid=1620224052&s=automotive&sr=1-4&ts_id=491445011
Put the luggage in the carrier Planes in the vehicle.  At $85 it may be cheaper than rent-a-trailer and you have it for more than one trip.
Another choice is a trailer hitch cargo carrier:
https://www.harborfreight.com/500-lb-capacity-aluminum-cargo-carrier-92655.html
Re: Plane transport
« Reply #6 on: May 05, 2021, 08:28:04 AM »
If you get the Sub - should be fine. I saw a great plane rack on facebook that held the planes vertically (nose down) and they had like 6 ships across the width of the back. I have done a carrier that held them stacked up and can get four max. Good luck and send pic's of how you packed it.
Best,   DennisT
Online William DeMauro
Re: Plane transport
« Reply #7 on: May 05, 2021, 02:01:01 PM »
If it is a one time thing it might cost less to just take 2 cars. Split the people, planes, and luggage up however it works. I do like the rooftop carrier idea too.
AMA 98010
Online James Mills
Re: Plane transport
« Reply #8 on: May 05, 2021, 04:23:42 PM »
Thanks for all the suggestions, I never considered the carrier rack on top.
James
AMA 491167
Re: Plane transport
« Reply #9 on: May 06, 2021, 08:15:56 AM »
  I have used a car top bag like the one pictured on my small Pontiac Vibe with much success. Make all luggage soft type and put all of that in the bag. Models and heavy stuff go in the car. I have use it in conjunction with the same cargo carrier from Harbor Freight that is shown also. I cut a piece of plywood to match the outline of the bottom of the roof top bag. I did MOT assemble the cargo carrier and left it flat. I attach the plywood to the cargo carrier and then the bar to that assembly with tie down straps. This all goes in the receiver on my Chrysler minvan. Same plan here, all soft luggage goes in the bag, and models and flight boxes go in the van. I think my bag is a Thule and I got it from Sears, which is hard to do these days, but I'm sure they are available some where else. The one depicted here in this thread is very similar. They are quite water proof if used correctly.
.   Type at you later,
Re: Plane transport
« Reply #10 on: May 07, 2021, 04:08:29 PM »
Here is an example of an ultra-modern car top carrier...
My father built this in the early 1950s and went to many meets with it. Red Reinhardt also used this carrier on occasion. Lots of memories for me. I remember it well; I even used it to go to the 1979 Team Trials.... And, I took a lot of abuse for it.
In those days we mostly just put clear dope over the carbon mat.
