  • June 27, 2025, 03:40:24 AM
Author Topic: Plane for PA 40  (Read 2837 times)
Offline Gene O'Keefe
Plane for PA 40
« on: November 18, 2010, 02:15:01 PM »
Okay - let's say you lucky enough to get a PA 40 Merlin ultra lite R.E.  ----- what plane would you put it in ?
Gene O'Keefe
AMA 28386
Offline John Miller
Re: Plane for PA 40
« Reply #1 on: November 18, 2010, 03:08:57 PM »
A Pathfinder L.E.
Grady Widener
Re: Plane for PA 40
« Reply #2 on: November 18, 2010, 03:27:54 PM »
Steve Buso Vegas with reduced aspect ratio (4 to 1 instead of 5) tail feathers that split 60-40 stab to elevator.
Offline Matt Colan
Re: Plane for PA 40
« Reply #3 on: November 18, 2010, 04:48:11 PM »
My Oriental Plus has had that motor in it all year, and flies it with ease, so that would be my recommendation  ;D
Re: Plane for PA 40
« Reply #4 on: November 18, 2010, 05:16:35 PM »
Well, that's a tough question. There are several from a light profile like Pathfinder to an Impact. Most any stunter from 600 to 700 square inches could be flown with the PA either with or without pipe. It's a good, solid and consistent engine.
Re: Plane for PA 40
« Reply #5 on: November 18, 2010, 06:23:01 PM »
I think Zuriel is wrapping a plane around one as I type this. I don't think his plans have been published yet.
Or maybe a Geo Jr?
Offline Aaron Little
Re: Plane for PA 40
« Reply #6 on: November 18, 2010, 06:56:38 PM »
Stiletto 660?
N30 and Pampa classes!
Re: Plane for PA 40
« Reply #7 on: November 18, 2010, 07:04:43 PM »
Now your talkin".
Chris...
Offline Doug Moon
Re: Plane for PA 40
« Reply #8 on: November 18, 2010, 08:11:16 PM »
Randy Smith designed Satona. Curt Contrada flew one into the Top5 in 2002.  It is an SV series plane but running around 630 squares.  Perfect fit for that motor.  At least I think so.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Steve Fitton
Re: Plane for PA 40
« Reply #9 on: November 19, 2010, 07:30:21 AM »
You would need to add some nose weight for that.  The 40 UL is much lighter than the regular PA 40 the plane was designed around.  But I bet it would be a killer motor in one of the Bear variants; I bet there is one that would be well suited to an 8.5 oz motor!
Offline Allen Brickhaus
  • ACE
Re: Plane for PA 40
« Reply #10 on: November 19, 2010, 08:01:18 AM »
I have contemplated a Buccaneer 740 or a Legacy 40 with the advent of smaller models with .65.  Jim Aron's stunter at the Nats flew well with a .65 in a 585 square inch model.  Thus a PA 40UL should not be an over-powering event in the Buccaneer 740 (575 square inches) or the Legacy 40 with 565 square inches.  I would put the gear in the wing and use a trench for the pipe.  This makes pipe length adjustments easier and clearance less of a problem.  Using a quiet pipe will tone done the sound of the pipe in a trench.  Simply draw a side view which will hide the pipe.
Allen Brickhaus
Offline Mike Scholtes
Re: Plane for PA 40
« Reply #11 on: November 19, 2010, 10:44:44 AM »
I have this motor on pipe in an Oriental Plus, 605 inches. This model was recommended to me by an elite flyer when I asked him the same question at the Golden State contest two years ago.
Offline Rick Campbell
Re: Plane for PA 40
« Reply #12 on: November 19, 2010, 11:18:47 AM »
Steve Buso's Kestrel would be great.
Re: Plane for PA 40
« Reply #13 on: November 19, 2010, 12:10:49 PM »
My three choices:
USA-1
Genesis MK III (.46 size)
Stiletto 660
Big Bear
Re: Plane for PA 40
« Reply #14 on: November 19, 2010, 12:13:54 PM »
Right you are Doug the Satona will work very well with this combo with a few very minor tweeks to the plane, nose moment and maybe trim the wing and stab down 1 inch
The other that will work very well are the
Standard Vector
Vector 40
Shrike
Staris
the Jaguar
Cobra
Ken Taylors' KISMET
Buso Lite Wave
USA-1...just ask Bob McDonald or Billy
Juno
630 Junar
Roadrunner
Cascade 545
VECTRA
lil  Bear
Stiletto first one , not  the  660 would be my choice of that series
Hallmark
Stunt machine
