  • July 19, 2025, 02:42:04 AM
Author Topic: Pics of my Scratch Cardinal - More pics added. Trim and Flaps.  (Read 3272 times)
« on: February 05, 2008, 04:44:59 PM »
Here are pictures of my Cardinal. It is just taped together. I will leave it in parts until I make room in the hanger. <=
Foam wing from Crist. I know I have a few wrinkles but this summer when the weather heats up I will pop it with the heat gun. Should clean up nice.
Power is a LA 46. Still need to cut flaps and make some landing gear. Has weight tip box, adj. leadouts. I will also add adj. trim tab.
No wheel pants cause I do all my flying off of grass. y1
Will add some trim colors too.
Paul H^^
« Last Edit: February 08, 2008, 09:42:11 AM by rootbeard »
Offline David Miller
  • CL, RC, Hunting and Fishing!
Re: Pics of my Scratch Cardinal
« Reply #1 on: February 05, 2008, 04:49:11 PM »
Way to go Rootbeard!! Looks great.
MSgt (RET) David G. Miller
AMA 560263
« Reply #2 on: February 05, 2008, 07:30:41 PM »
Looks great, lets us know when its finished and flying.  DOC Holliday
Offline Joe Connelly
« Reply #3 on: February 05, 2008, 10:01:08 PM »
Hey Paul,
  Looks like your Cardinal hatched a couple of babies. A yellow one and a blue one. Looking good Paul.
        Joe Connelly y1
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #4 on: February 05, 2008, 10:14:02 PM »
Looks like a geat job! Beats watching TV all the time.
« Reply #5 on: February 05, 2008, 10:17:19 PM »
Looks good, Paul. Every plane you build, you're skills improve.
Offline Leo Mehl
« Reply #6 on: February 06, 2008, 09:40:30 AM »
Ya, next thing you know you will be building Grinders and things like that.Good job my friend.
« Reply #7 on: February 06, 2008, 12:43:43 PM »
Thanks guys!
I sure wish I had a good place to build, and more time to build. If I can ever figure out how to retire and get a real shop. But by then all my paint and glue will be dried up.
 HB~> Z@@ZZZ D>K
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #8 on: February 07, 2008, 06:57:03 PM »
Looking good Paul.
Nice work blending the sewn hinges in.  You really have to look hard to see them.
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
Offline Zuriel Armstrong
« Reply #9 on: February 08, 2008, 07:53:34 AM »
Paul,
That looks great, but I would swear the top of your outboard elevator says "BOTTOM" VD~
Zuriel Armstrong
AMA 20932
« Reply #10 on: February 08, 2008, 08:25:43 AM »
Yea I just slide it in for the pic. It says bottom due to that is how the monokote was put on. Seems go to the bottom. It will be right when I glue it in for good.  n~
But then if I do glue it in upside down, it will be right when I fly inverted. <=
Paul H^^
« Reply #11 on: February 08, 2008, 09:41:39 AM »
OK Zuriel,
I turn the stab over and added some trim. Also cut the flaps.
It's starting to look like it is ready to fly! y1
Re: Pics of my Scratch Cardinal - More pics added. Trim and Flaps.
« Reply #12 on: February 08, 2008, 10:20:59 AM »
Paul,
Nice tail 8)
Zuriel Armstrong
AMA 20932
« Reply #13 on: February 09, 2008, 06:42:12 PM »
wheres the wingtips????   CARDINAL sin leaving those off!!!! LL~ LL~
« Reply #14 on: February 10, 2008, 08:29:06 AM »
Sorry Wynn,
This not going to be a real "show" plane. I hope not but this one might take a bit of a beating. Don't want to put a lot into as far as details.
Paul  H^^
Offline Leester
« Reply #15 on: February 10, 2008, 11:23:14 AM »
Wynn: YOU BAD
Leester
ama 830538
« Reply #16 on: February 16, 2008, 04:41:05 PM »
Pics of Kelly Wilsons Coyote
Offline Kafin Noe’man
« Reply #17 on: May 28, 2022, 04:59:32 PM »
OK Zuriel,
How did it fly without the wingtip?
I’m currently building the Cardinal, but too lazy to sand-to-shape the wingtip  LL~
If yours fly well, I might also do the same.
Offline John Carrodus
« Reply #18 on: May 29, 2022, 01:40:17 AM »
Paul- A clean job - she looks as slick as lightning.
« Reply #19 on: May 29, 2022, 07:46:04 AM »
 Wow this is a flash from the past.
The plane flew but it was a wall hangar. I think I had a misalignment somewhere.
« Reply #20 on: May 29, 2022, 08:43:00 AM »
Thinking on this a little more. I built two fuselages and I ended up putting a yellow fuse on this plane. I made a green canopy out of a pop bottle. It was a learning experience.  I gave away the plane to one of my son’s friends.
It was wall hangar for me. 😛
« Reply #21 on: May 29, 2022, 09:15:26 AM »
 ;D ;D ;D
So, you’re telling me it’s not worth the try, aren’t you?
I’m still learning to fly stunts, and I just crashed my other plane.
I would like to get back to the field as soon as possible and spend more time on flying.
So, I was thinking that making the wingtip square will save times.
« Reply #22 on: May 29, 2022, 10:34:57 AM »
I think building it straight just as a trainer I think you can square off the tips. IMHO.
But if you just want a ground beater to learn on go with a Twister. Smaller plane and less wood.
Good luck.
