  • July 08, 2025, 01:25:09 PM
Author Topic: Petternmaster wing flaps.  (Read 1198 times)
Online Perry Rose
« on: August 22, 2013, 11:44:14 AM »
   I'm drawing up a new stunter using a foam core Patternmaster wing. Can someone tell me the chord width of the flaps at the root and tip for the original Patternmaster?
Offline Bootlegger
Re: Petternmaster wing flaps.
« Reply #1 on: August 22, 2013, 03:33:45 PM »
 Perry, you might check with Windy U.  Good luck, and keep us posted..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline jose modesto
« Reply #2 on: August 22, 2013, 03:46:46 PM »
What's the root and tip. Can you also measure the highpoint and last, span of cores
There were 4 PM by Big Jim
There were many clones
I have 2 of Big Jims Pattern Master wing templates.
Jose Modesto
Mike Griffin
« Reply #3 on: August 22, 2013, 05:02:47 PM »
Perry I dug out my plans of the Pattern Master that Big Al Smith sent me...the root chord of the flap measures 3 3/8" and the Tip Chord measures 1 1/4".  I hope this is what you needed.
Online Perry Rose
« Reply #4 on: August 22, 2013, 05:24:07 PM »
That's what I needed, thanks Mike.
Mike Griffin
« Reply #5 on: August 22, 2013, 05:28:18 PM »
You are welcome Perry....glad to help
« Reply #6 on: August 22, 2013, 06:05:45 PM »
Mike is correct when speaking of the "Big" Patternmaster.  There are at least three other "official" Big Jim Paternmasters and who know how many other "Patternmasters".
Perry, are the cores long enough to have about a 62" Wingspan with tips added?  If so it sounds like the "Big Patternmaster.
BIG Bear
RNMM/AMM
Online Perry Rose
« Reply #7 on: August 23, 2013, 04:13:07 AM »
Bill, yes the cores are 30 inches long each.
« Reply #8 on: August 23, 2013, 12:56:54 PM »
Hi Perry,
The flap numbers given are for those cores.
BIG Bear
RNMM/AMM
