  • July 03, 2025, 06:28:59 PM
Author Topic: Question: K&B Torpedo 35C  (Read 1939 times)
Offline Phil Coopy
« on: February 14, 2008, 08:09:08 AM »
Saw a K&B Torpedo 35C Greenhead sold on Ebay for a bunch.  How can you tell the K&B 35C(combat version) from the regular K&B 35 Green head?
Phil
Re: Question: K&B Torpedo 35C
« Reply #1 on: February 14, 2008, 08:57:17 AM »
I don't know if the head has *35C* stamped in it, so I can't say about the external ID.  But the crank does have a stamp on it.
Offline tom hampshire
« Reply #2 on: February 14, 2008, 09:03:06 AM »
Hi Bill - Don't think the head had a stamp, there was a sticker 'C' on the bypass.  The shaft was the primary difference, had a smaller bore to the port.  Seems K&B couldn't get the original greenhead shaft to survive, so they made it thicker cross section.  The original greenhead crankshaft is interchangeable with a McCoy redhead.  Tom H.
Offline wmiii
« Reply #3 on: February 14, 2008, 09:29:32 AM »
 The piston had a single oil  groove near the top. The cranks still broke frequently, as we ground on them, not knowing  what we were doing.
 Walter
walter menges
Offline Richard Entwhistle 823412
« Reply #4 on: February 15, 2008, 08:31:46 PM »
New 35C's in the box will have a tapped boss in the center of the back plate with a big round headed slotted screw as a plug.  The plug screw will be bright but some were finished in black.  I have two new in the box and have not seen the sticker on the case.  They may have been removed or fallen off.  The combat crank is stamped with a "C" and the piston and liner are a different part number than the stunt engine.
Later
Richard
Scappoose OR
Offline Garf
    • Hangar Flying
« Reply #5 on: February 15, 2008, 09:54:14 PM »
Bigger cyllinder ports, different crank, different backplate, head marked 35C, oil grooves in piston.
Offline Phil Coopy
« Reply #6 on: February 16, 2008, 05:35:56 PM »
Thanks guys.......mine's not. :-[
Phil
Offline Marvin Denny
« Reply #7 on: February 16, 2008, 08:10:43 PM »
  I just got through checking my two in the junk barrel.  Both have the tapped plugged backplate, the 35 C on the crand counterweight but no 35c on the head.  The cylinder ports seem bigger than the standard 35 and the piston s have a groove around them near the top
  Funny, I ran them in both Rat ?Race and Combat and could pretty well stay up with Riley Wooten and carl Berryman back in those days and never had a shaft breaking problem after the first one and then I found out why and corrected the problem.
  Bigiron
marvin Denny  AMA  499
Offline Keith Spriggs
    • khspriggs
« Reply #8 on: February 17, 2008, 09:43:20 PM »
I am glad this came up. I picked up a KB 35 a while back. I see that is a 35C. The crankshaft is stamped "35C". I also picked up a McCoy Redhead that is a .29. When I took it apart I noticed that the connecting rod was marked 35. I assume the 29 and 35 used the same connecting rod. ???????????
Offline Bill Gruby
« Reply #9 on: February 18, 2008, 01:45:00 AM »
 Hi All
  The crank on a 35C is stamped as such as Marvin has already said, but the easiest way to tell is by the serial number, it will have a 'G' prefix. The numbers ran from G00100 to G07000. Just one more way to tell.
  "Billy G"  H^^
Bill Gruby
AMA 94433
MECA 5393-10
    • khspriggs
« Reply #10 on: February 19, 2008, 11:32:41 AM »
Hi All
  "Billy G"  H^^
Once again the G-Man scores a bullseye. The serial # on the engine I have is G6878. I guess that would be one of the last ones built if they run through 07000
