Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 20, 2025, 02:51:23 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
panel lines
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: panel lines (Read 1497 times)
Doug Kretschmar
Trade Count:
0
New Pilot
panel lines
on:
November 10, 2016, 08:51:18 PM »
Hi. I was thinking of trying panel lines and was wondering if a Sharpie pen would work. The way I understand the process, is you put a line down and then when finished dust on a couple of coats of dope to seal and then finish as normal. Have I missed something? I tried it on an old airplane and it seemed to work.Just seems too easy not having to mess with drafting pens. Thanks Doug
Logged
wwwarbird
2016 supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Re: panel lines
Reply #1 on:
November 10, 2016, 08:55:27 PM »
Fine line Sharpies will work.
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: panel lines
Reply #2 on:
November 10, 2016, 08:57:39 PM »
And if you mess up before the clear is sprayed, alcohol will remove it.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Paul Taylor
25 supporter
Trade Count:
0
Admiral
If God is your Co-pilot - swap seats!
Re: panel lines
Reply #3 on:
November 10, 2016, 08:58:40 PM »
Go to Office Depot and get a $8 pen. I did it on my last profile and it worked out ok.
Do a search and it should turn up my thread and a picture of the pen.
Also suggest you search my YouTube channels for some of Windy's videos. He did a few on ink lines.
Logged
25 supporter
Trade Count:
0
Admiral
Re: panel lines
Reply #4 on:
November 10, 2016, 08:59:06 PM »
Top Flite used to put out a pen that worked Ok also. Do a search on the forums and all sorts of stuff should come up, including usin the Rapido-graph pens and proper technique.
dan Mcentee
Logged
EAA 1038824
Avaiojet
22 supporter
Trade Count:
0
Admiral
Just here for the fun of it also.
Re: panel lines
Reply #5 on:
November 10, 2016, 09:38:45 PM »
Doug,
I did a Thread some time back on panel lines. "Secret Exposed." A search should bring it up. It was my first attempt actually.
I tried a few pens and did clear coat tests.
Not all pen ink is the same and clear did attack a few pens.
Here's the pen that was the easiest to work with and clear had no effect on the ink. The model also. I purchased a black and a blue one.
If you have interest in seeing my pen lines on a model and how easily I pulled it off, here's where the Thread is located.
http://stunthanger.com/smf/paint-and-finishing/secret-exposed!-pen-lines-photos-added!!/
If the link doesn't work, it would be page five. Look for the Thumb Up.
Good luck.
Charles
Logged
If you're Trolled, you know you're doing something right. Alpha Mike Foxtrot. "No one has ever made a difference by being like everyone else." Marcus Cordeiro, The "Mark of Excellence," you will not be forgotten. "No amount of evidence will ever persuade an idiot."- Mark Twain. I look at the Forum as a place to contribute and make friends, some view it as a Realm where they could be King. Proverb 11.9 "With his mouth the Godless destroys his neighbor..." "Perhaps the greatest challenge in modeling is to build a competitive control line stunter that looks like a real airplane." David McCellan, 1980.
TigreST
TigreST
2017
Trade Count:
0
Commander
Re: panel lines
Reply #6 on:
November 11, 2016, 02:55:17 AM »
Here's a little bit of info on some technique that worked for me some time back. Like anything else, practice makes for perfect.
http://www.tulsacl.com/PanelLines.html
I used the Top Flight pen for the black lines, and then went looking for a local replacement from it. I found Staedtler pens at the local Staples. These are permanent ink pens, available in different tip widths.
Logged
Tony Bagley
Ontario, Canada
Howard Rush
25 supporter
Trade Count:
0
Admiral
Re: panel lines
Reply #7 on:
November 11, 2016, 10:28:55 AM »
I use an old carbide-tip drafting pen with water-soluble (not permanent) ink. Goofs in water-soluble ink are easier to get off. Spraying with clear locks down either type ink.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
panel lines
