  • July 18, 2025, 06:51:03 PM
Author Topic: pull test scale source?  (Read 1222 times)
Offline Fred Cronenwett
    • Lafayette Esquadrille
« on: May 11, 2015, 08:45:10 PM »
Has anyone purchased one of the pull scales that we use at our contests that can pull over 100 lbs? I am looking for one of the those long rectangular pull scales that spring based
Looking for a source for those...
thanks
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Re: pull test scale source?
« Reply #1 on: May 11, 2015, 08:57:07 PM »
Fred,
This site carries up to 110 lbs and they are cheap.
There are other sites that carry higher weights...some are not so cheap!
http://www.amazon.com/s/?ie=UTF8&keywords=fish+weight+scale&tag=mh0b-20&index=aps&hvadid=3527198147&hvqmt=e&hvbmt=be&hvdev=c&ref=pd_sl_7b0ulohi5u_e
Online Howard Rush
« Reply #2 on: May 11, 2015, 09:05:17 PM »
That would sorta complement Fred's vacuum tube ESC.
« Reply #3 on: May 12, 2015, 07:26:20 AM »
The weight stack with a pulley follows the "honest weight no springs" concept.  As mentioned elsewhere, the spring type fish scale relies upon the operator to see when the target force has been achieved and slack off before destroying the model.
« Reply #4 on: May 12, 2015, 09:04:03 AM »
Try a farm & feed store -- those things are often used for weighing hay and other feed for animals.
I've got one of those (filched from the wife's barn) and a digital fish scale.  They both work.
Offline sleepy gomez
« Reply #5 on: May 12, 2015, 03:29:48 PM »
I made one using a clicker type, adjustable torque wrench.  The control handle is hooked to the end of the torque wrench handle. Set to the desired pull there is an audible click when the pull is reached. This click can also be felt at the plane. The square drive end of the wrench attached to a socket welded to a plate.  This type can be used with only the person holding the plane.
Online Howard Rush
« Reply #6 on: May 12, 2015, 11:50:22 PM »
Cool idea.  Thanks.
« Reply #7 on: May 13, 2015, 09:33:55 AM »
Amazing how some can't accomplish that simple task.
