I may have mentioned this as an aside before, but when you are flying the first flight after some engine adjustment/change/fix, be very careful and check it out in a safe way first. That way, if the engine unexpectedly quits, you have a chance of saving the airplane. I suggest several inside loops to start. That's the most likely place for it to crap out/flame out for inverted-mount engines. Listen very carefully to how it runs, and in particular, if there are any unexpected misfirings or the engine seems like it "goes rich", particularly at the bottoms of the loops, beware. If that sounds OK, then flip it over and try some outside rounds. You might try a hard corner each way, too.
Be particularly careful after a glow-plug switch or testing a new plug. Sometimes, a new or different glow plug will just cause engine to quit dead, sometimes with NO warning like you flipped a switch. I have no idea why and have heard no plausible explanations. It tends to happen more with ABC/AAC engines. Many times, if you go over attach a battery and flip it, it starts like nothing happened, then will do it again.
Fuel matters, too, and my best guess (which is poor and hand-wavy) is that the issue is somehow related to the combination of fuel and glow plug element material and some combinations are chemically questionable, and/or to not have the same catalytic action.
Some engines are more prone to it than others, too. I had what seemed to be identical engines from a super-high quality manufacturer. One ran fine in any condition, the other would run 30 seconds -minute on the bench, then quit like you flipped a switch. Start it back up with no changes, sounds fine, then another flameout. Same thing in the air, it would "load up" (i.e misfire severely) at the first inside loop, even worse in the second, and then it would quit in the third, time after time. Glow plug or conditions appeared to make no difference. The *only* fuel that particular engine would run reliably on was Byron "Classic", and then at astronomical (and extremely noisy) launch revs of ~12,000 rpm*. The other seemingly identical engine ran fine in the same conditions, with no issues and not fussy about fuel at all. It took me about 1 year or so of testing, etc, measuring everything you can measure, etc, and I found *no dimensional* differences at all to about .0001 in anything. Put it all back together, one engine worked, the other didn't.
Needless to say, if you make some change, take off, jam in a hard corner to enter the wingover, and it quits, you are slow (since you just turned a hard corner), upwind, and slowing rapidly because you are vertical. The chances of saving the airplane in that situation are very low.
So be careful.
Additionally, after having seen the results time after time, I would categorically reject the use of Rossi plugs. They seem to have this problem time and time again, even on the ground, in all sorts of engines. Ted discovered this the hardest possible way at the NATs one year, but many others have had the same.
So any time you are testing/changing/fixing any engine problem, be very careful for the first few maneuvers, keep the airplane alive.
