  • July 15, 2025, 06:31:06 PM
Author Topic: Paint under transparent monokote  (Read 1655 times)
Online Paul Taylor
« on: January 31, 2025, 05:26:45 PM »
Still thinking about doing some transparent monokote. I was wondering if I could paint (rattle can) the LE and TE sheeting and cover with Transparent.
Anyone have any experience?
Offline peter jurczyk
Re: Paint under transparent monokote
« Reply #1 on: February 01, 2025, 05:28:50 AM »
The paint will just bubble and kinda like smear at least that's what happened to me. Plus the paint gets slippery as is not sticky to the monocote
« Reply #2 on: February 01, 2025, 06:55:44 AM »
I have had moderate success using ModPodge under MonoKote.  It has close to the same adhesive properties as BalsaRite and it comes in colors.
I use it mainly just on the fuselage to help hold down the MonoKote on the concave curves.   Give it a day or two to dry (water based) before sanding the fuzz off and dry wipe it thoroughly after sanding.  I have had the "toad warts" that Peter alluded to if I didn't let the ModPodge dry enough.  If you can find a color close to the monokote you might avoid the glue smearing, which it will do, showing as much.
Offline Perry Rose
« Reply #3 on: February 01, 2025, 08:09:39 AM »
One of the Ehling (sp) brothers did a ringmaster with clear monokote. The wing structure (ribs, spars sheeting) was colored somehow.
Offline Dave Harmon
« Reply #4 on: February 01, 2025, 08:38:17 AM »
I've thought about trying this but have not so far.
Dying the wood might work ok without smearing because there is no glue....
Wipe it on like a stain....or use a stain...food coloring/alcohol in a spray bottle...
Interesting idea...
Online Motorman
« Reply #5 on: February 01, 2025, 11:26:11 AM »
I tried coloring wood with Rit dye, it did not go well at all.
MM :)
Online Dave Rigotti
« Reply #6 on: February 01, 2025, 01:28:01 PM »
WIDE tipped magic marker.....
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Dave Harmon
« Reply #7 on: February 01, 2025, 04:32:53 PM »
I tried that...several times....the marker bleeds and shows through the back of white film covering....might be ok for clear covering though.
I had been coloring servo and engine compartments with black marker....bled through the covering.
I changed to colored butyrate and no bleed....then painted with thin clear epoxy. (BSI Finish Coat)
« Reply #8 on: February 01, 2025, 09:35:40 PM »
I did a couple of Small profile planes using magic markers for color in areas I wanted a color.   No problem with transparent MonoKote staying stuck or smearing.   Getting the color solid enough was time consuming. D>K
Online Paul Taylor
« Reply #9 on: February 02, 2025, 06:52:20 AM »
Well I think this changes my direction.
Thanks for the input.
Online Dan Berry
« Reply #10 on: February 02, 2025, 08:10:35 AM »
You can thin ink with dope thinner and spray it.
Dykem layout fluid works but your color palette is quite limited there..
Offline Perry Rose
« Reply #11 on: February 02, 2025, 02:02:30 PM »
The coating needs to be non aqueous.
« Reply #12 on: February 02, 2025, 03:58:08 PM »
Why is that?  I use ModPodge which is water based
