I haven't run the 67 at all, so I can only compare what I see from the outside. I think the 67 would probably do better as an ST60 or Saito 56/72/82 upgrade than a replacement for a PA61. I
know I will get flamed again, but I really don't see any good competitive reason to run in 4-2 with a muffler and giant 6" pitch prop like it was still 1985, even a really good one like the 67. But people still seem to want that, and do well in some cases, so, heck, I am probably just stupid like the hate mail said.
I couldn't be happier with my RO-Jett 61s (140 and 144 exhaust duration, AKA "Brett version"). They seem to solve all the issues and nits I had to pick with others. It's not quite as easy to keep running perfectly as a OS40VF (which is far and away the most reliable/repeatable stunt engine of any kind I have ever seen) and it doesn't have quite the "power" as the PA61/65, but overall it works like a gigantic super-powerful OS46VF.
The setup has been repeated over and over, and I have varied it as an experiment over the years, but I always come back to the settings I discovered right before the 2003 NATs. Literally never think about it for *11 years* no matter what the conditions might be, adjust the nitro to get the same operating point, it runs the same. I have been running the exact same engine since right before the 2007 Team Trials, and while I don't think I fly very much compared to others, lots of cases of fuel have come and gone in that time.
For what it is worth, I haven't seen the same sort of repeatability with the RO-Jett 65 that I have with the 61. That may be because all the 65's I saw and the one I ran was the 136-degree version. I never got the 136 "standard" version or either the 61 or 65 to run properly in the manner I like, it just didn't seem to be as stable at normal flight revs of 10800-11000.
p.s. throwing caution to the wind, I would also note that the OS20FP and "new" 25LA are just about as repeatable and have the same outstanding run quality as the 40/46VF - if you leave them alone. "Fix" or "improve" them, and you are on your own.
