  • July 08, 2025, 11:36:16 AM
Author Topic: PA needle valves assemblies back in stock  (Read 1512 times)
« on: January 12, 2017, 07:54:07 PM »
PA  needle valves assemblies  back in stock, along  with all parts
Randy            678 407 9376     see  my vendor  section
« Last Edit: January 15, 2017, 07:36:56 PM by RandySmith »
Offline Lyle Spiegel
Re: PA needle valves assemblies back in stock
« Reply #1 on: January 14, 2017, 03:41:25 AM »
Randy, do you have the version sized to fit Fox 35? Last time I check they were not available?
Lyle Spiegel AMA 19775
« Reply #2 on: January 14, 2017, 09:06:37 PM »
NO  but I can fit most other motors,  since  FOX 35 are  not made in many years now  I cannot  run  a run of those
What I can setup is  a OS LA  NVA  that has soft aluminum shims  to fit the  FOX 35, nit as good as a PA  NVA  but  far better than the  Fox one
Offline kenneth cook
« Reply #3 on: January 22, 2017, 06:14:45 AM »
              Randy, is the Fox .35 version just a turned down center of the stock version? Ken
« Reply #4 on: January 22, 2017, 07:31:30 AM »
Randy,
How many different size NVA's do you offer?
Charles
« Reply #5 on: January 22, 2017, 08:15:59 AM »
blank
« Last Edit: March 06, 2022, 04:12:38 PM by Motorman »
« Reply #6 on: January 22, 2017, 05:23:52 PM »
NO it is a  total different size   and it was made of Steel
Not made any longer
« Reply #7 on: January 22, 2017, 05:27:32 PM »
Randy,
Charles
I have many sizes and brands of NVAs  here   OS   ENYA    ST   etc... and   PA
The PA  is  one size   fits all  PAs, ST 51 60 , Magnum  BB engines , TT  BB engines  plus many others  as  is,  I have  soft metal spacer  for the  PA assembly  that makes if fit the   OS  LA  FP  series   Mag  GP  TT  GP series   Enya    ST 35 40 46   Brodak   K77     and many other motors
