  • July 15, 2025, 04:19:13 PM
Author Topic: PA 61 Powered Sea Fury  (Read 1863 times)
Offline kevin king
« on: October 16, 2023, 06:51:26 PM »
Check this Sea Fury out. Built and flown by Monty Summach @ the 2023 Canadian team trials. Respectable 4th against some of the top pilots in Canada.
 https://youtu.be/ofdw6X5WJcI?si=kCn6eK8rFBOwb03t
« Last Edit: March 24, 2024, 05:07:59 PM by kevin king »
Online Walter Hicks
Re: PA 61 Powered Sea Fury
« Reply #1 on: October 16, 2023, 07:27:11 PM »
Thanks for sharing that. Was this a Rabe Sea Fury or his own design?
Offline kevin king
« Reply #2 on: October 16, 2023, 09:12:45 PM »
Walter, to be honest I am not sure If its his or Al's design. Its not his first Sea Fury so i am guessing Its a little bit of both by now
Offline Doug Moisuk
« Reply #3 on: October 16, 2023, 09:29:57 PM »
This is from the MAAC CL TEAM TRIAL REPORT.
Doug Moisuk
MAAC 3360L
Offline Robert Whitley
« Reply #4 on: October 16, 2023, 10:39:27 PM »
That’s Monty’s second Sea Fury, both his own design.
I’m not certain of this one’s power plant but I think his earlier one was propelled by a 61.
Offline kevin king
« Reply #5 on: October 17, 2023, 01:03:32 AM »
But power was mistakenly  listed as a PA 75. It is in fact a PA 61.
« Reply #6 on: October 17, 2023, 12:12:59 PM »
Great looking plane.  Even with the camera not being in the right place you can see where he gave away points.  Of course he is probably still trimming the plane but hsi bottoms need to be more consistant as well as his intersections.  Really he is a much better pilot than me.  Stay with it kid. D>K
Offline Monty Summach
« Reply #7 on: October 17, 2023, 04:58:47 PM »
Thanks for your comments. The team trials was a very good contest highlighted some (many) areas where I could make improvements. Doc said it, bottoms and intersections.
This Sea Fury is inspired by Al Rabe, but is my own design. Airfoil is different, flaps area is less, tail volume is greater, nose is longer. Pipe runs through the fuselage above the wing.
Power is PA61. It has not been a trouble free ride, but is getting better day by day.
Monty
Offline kevin king
« Reply #8 on: October 17, 2023, 06:53:14 PM »
The video was a practice flight. Hope he doesn't mind, but here's some of  his official flights i recorded.
https://youtu.be/1luCAYzDGvg?si=Wq11tVSMwSj5E7tdp
« Last Edit: October 18, 2023, 08:50:42 AM by kevin king »
« Reply #9 on: October 17, 2023, 11:21:39 PM »
Monty
       It sounds *exactly" like the setup I used on the PA61, it's kind of uncanny.
« Reply #10 on: October 18, 2023, 09:01:59 AM »
Much better flight.  Still a few spots need work.  Thanks for the video. H^^
