  • July 11, 2025, 06:09:03 AM
Author Topic: Setting Problems  (Read 976 times)
Offline Garf
    • Hangar Flying
Setting Problems
« on: June 10, 2007, 04:37:14 PM »
As the temps near 90 and the humidity rises, I am having trouble getting good needle settings. What changes do I need to make to help with this problem? I am running Johnson and Super Tigre 35's. I think I need to adjust nitro and oil levels. Any ideas?
Offline Peter Nevai
    • C3EL
Re: Setting Problems
« Reply #1 on: June 11, 2007, 09:55:41 AM »
Hmmm. We need a chemical engineer in on this one.
Need to cool the fuel and have it burn colder in the engine. At 90 degrees the fuel is already trying to vaporize at a accellerated rate. Put  the fuel in a cooler with ICE and keep the tank covered with a towel out of the direct sun may help.
Any Ideas anyone?
Hmmmm. I wonder if anyone tried keeping thier fuel on Ice before.
Offline Garf
    • Hangar Flying
« Reply #2 on: June 16, 2007, 03:44:08 PM »
I set up a marathon engine running session today to test various things. Seems the plugs that ran fine under other conditions wouldn't work under these conditions. I also had a compression leak in the Johnson SS. A few new Thunderbolt plugs helped. Now to see how they fly. I need to order some more.
