  • July 15, 2025, 07:28:42 PM
Author Topic: Otto the Giro (Gyro) Kit -  (Read 7647 times)
Offline Mike Griffin
« on: January 02, 2016, 02:37:54 PM »
This is an edit to my original post.  OTTO THE GIRO kits are no longer available.
Thank You
« Last Edit: July 06, 2016, 06:21:20 PM by Mike Griffin »
Offline pipemakermike
Re: Otto the Giro (Gyro) Kit Survey
« Reply #1 on: January 04, 2016, 04:59:22 AM »
Hi Mike
There is a "better" plan and the article regarding the model on the outerzone site.
Here is a link to the article:-
http://www.outerzone.co.uk/planfile_supplement/7346/7346_article.pdf
And the plan:-
http://www.outerzone.co.uk/plan_files_07/7346/Otto_The_Giro_Gyrocopter_Plans.pdf
Mike Nelson
« Reply #2 on: January 04, 2016, 05:23:52 AM »
Thank you Mike.
Offline Will Davis
« Reply #3 on: January 04, 2016, 07:33:04 PM »
If you question  if it can loop, here is proof .  , David smith flying  a very old one on throttle .
Will Davis
"Carolina Gang"
Offline Allan Perret
  • Proverbs
« Reply #4 on: January 04, 2016, 09:32:19 PM »
That thing is a riot, I WILL build one.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #5 on: January 04, 2016, 09:46:09 PM »
I wouldn't advise the loop, Allan. Looked a bit treacherous.
« Reply #6 on: January 05, 2016, 05:33:16 AM »
I have talked with Dick Mathis and gotten some more information I needed and also Eric Rule about getting it into a CAD format so a kit can be cut.  If there is sufficient commitment from enough folks to make it economically feasible to proceed, I will.  Right now there is not.  I am with ALLAN, I think this thing would be a blast.  You do not necessarily have to run throttle control either, that is an option.
« Last Edit: January 05, 2016, 07:39:46 AM by Mike Griffin »
  • Proverbs
« Reply #7 on: January 05, 2016, 08:49:43 AM »
Yes, but that's part of what makes it fun, pushing it to the limits.  I am planning on some performance "enhancements".  Also on Jim Lee's recommendation, will go to the field with spare rotor assy's.
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #8 on: January 05, 2016, 09:49:22 AM »
Hey Will, do you know what motor David is using in his gyro ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline BYU
« Reply #9 on: January 05, 2016, 09:56:59 AM »
Re: For Sale - Boxcar Chief Laser Cut Short Kits
« Reply #4 on: November 22, 2015, 06:16:46 PM »
“Quote from: Bill Morell on November 22, 2015, 11:52:18 AM
Interesting, every time you put out a new kit you claim it is the last  one you will produce.”
“Do not remember saying that before but this is my last kit.  All my previous kits are still available but I will not produce anymore for sale”
« Reply #10 on: January 05, 2016, 06:25:52 PM »
Sent you a PM. Uncle
Offline WR Crane aka MrClean
« Reply #11 on: January 05, 2016, 07:53:03 PM »
What?  No balloon popping videos?  Well then you've missed Otto's calling.
Offline Myron Firmin
« Reply #12 on: January 06, 2016, 08:44:55 AM »
Well Mr Bob, I kinda appreciate Mike and others like him trying to breathe new life and interest into our hobby, especially since we are not getting good press with our friends with drones.
Myron Firmin
Definition: Work Bench, a place to stack stuff, so you can build on the card table.
www.facebook.com/ringmastersflyingclub
« Reply #13 on: January 06, 2016, 10:06:07 AM »
Thank you Myron.  I have said a couple of times I was going to retire and I guess I will some day but things just keep popping up that are just too much fun to ignore.  I have to thank ALLAN Perret for getting me interested in the Otto the Giro project.  Even though I had kitted some of Dick Mathis's designs in the past, I was not aware of this one until ALLAN brought it go my attention.  I think it will be fun...
« Reply #14 on: January 06, 2016, 04:07:41 PM »
Deleted
« Last Edit: July 04, 2016, 09:21:38 AM by Mike Griffin »
Re: Otto the Giro (Gyro) Kit ITS A GO
« Reply #15 on: January 06, 2016, 04:21:12 PM »
Please go here (click the link) for further details on the kit..
http://stunthanger.com/smf/griffin's-model-service/sign-up-for-otto-the-giro-kit/msg431467/#msg431467
Thank you Mike
  • Proverbs
« Reply #16 on: January 09, 2016, 08:26:35 AM »
Hi Mike
And the plan:-
The .pdf file for the construction article at outerzone is missing a page.  It has page 17 & 19.    Anybody have a lead on page 18 ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Will Davis
« Reply #17 on: January 09, 2016, 10:27:35 PM »
Allen,
David uses a old enya. Baffle motor, it is a 29 or 35, the model was built by David's father, nothing but fun, David has a newer bigger model in the works , at the end of the flight , if you watch him close , you can see  his model shear a blade ,and he was able to about ,   just a little too much stress
Will Davis
"Carolina Gang"
  • Proverbs
« Reply #18 on: January 13, 2016, 07:21:26 PM »
Allen,
I re-designed the rotor hub for Mike's kits because it looked to be both weak and hard to make accurate.  My hub has more than twice the gluing surface vs the original.  I made a jig to cut them on a table saw.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Larry Renger
Re: Otto the Giro (Gyro) Kit - New Info posted 1/7/2016 - Pricing etc.
« Reply #19 on: January 14, 2016, 08:06:28 AM »
 wonder if anyone ever flew an autogyro off a carrier. Talk about slow flight capability!  LL~
Offline Dan Berry
« Reply #20 on: January 14, 2016, 08:46:17 AM »
I think they did it off the Langley.
Model Builder had an article on autogyros that mentioned it.
Offline skyshark58
  • skyshark58
« Reply #21 on: January 14, 2016, 10:54:41 AM »
Rotary wing aircraft are not legal for carrier event.
mike potter
« Reply #22 on: January 16, 2016, 03:26:14 PM »
Deleted
« Last Edit: July 04, 2016, 09:22:24 AM by Mike Griffin »
Offline Andrew OGrady
Re: Otto the Giro (Gyro) Kit - Will now be available in Electric Version
« Reply #23 on: July 03, 2016, 01:05:56 AM »
Hi, can you please let me know if the Otto The Giro kits are still being produced? Thanks, Andrew
« Reply #24 on: July 03, 2016, 08:13:35 AM »
HI Andrew
Although I no longer produce kits anymore, most of the kits I did over the past years are still available on special request except for the Otto the Giro kit.  It was only available for limited amount of time due to the custom machining that had to be done to make the rotor hub which I had to outsource.  Unfortunately it is not economically feasible to set up production for one hub.  This was the only kit I did that was a one time run.
Mike Griffin
