  • June 30, 2025, 03:20:13 PM
Author Topic: 40 VF , OS 40 ( forty ) VF AAC piston sleeve now in stock  (Read 4904 times)
« on: August 15, 2017, 12:58:08 PM »
OS 40 VF  AAC  piston sleeve set
THESE  are  now  finished  and  in stock ,  If you want these , please  place your order with you information ,
Randy   678 407 9376
Randyaero@msn.com
additional :
Along with the  second batch I sent out I am including  new  G Clips for  retaining the pin, When you install the new piston sleeve set, make sure you put the rod on with the chamfer on the bottom bushing, pointing toward the front of the  motor, make  sure  you case is  clean inside, and  has  NO cuts scratches or carbon, that will interfere with the aluminum sleeve, if there is  sand it smooth, hone it smooth , or  call me.
Lubricate the inside case and the outside of the sleeve with copious amounts of  thick oil, like castor .
If there is any interference and the sleeve stops, do not force it. use common sense and  you will be  OK
There should not be any problems  changing the  P/S out in your motor, and you will  lose an ounce
If you need any parts please contact me
« Last Edit: April 07, 2018, 03:31:08 PM by RandySmith »
Offline big ron
Re: OS 40 VF AAC piston sleeve set survey
« Reply #1 on: August 15, 2017, 06:43:16 PM »
I would take a set
John Blanchard
Brusly, Louisiana
 AMA 1054488
« Reply #2 on: August 15, 2017, 07:41:28 PM »
These , unlike the  46 VF  ABC  sleeves  will be   AAC  and will make your 40 VF  near 1 ounce  lighter
Offline Ted Klein
Re: OS 40 ( forty ) VF AAC piston sleeve set survey
« Reply #3 on: August 15, 2017, 07:53:11 PM »
I'd go for a set too.
AMA 559213
Offline tom_weedman
« Reply #4 on: August 16, 2017, 02:40:48 AM »
I will take a set Randy
Thanks Tom Weedman
AMA 63672
« Reply #5 on: August 16, 2017, 09:13:16 AM »
Put me down for two sets.
Offline Gordon Tarbell
« Reply #6 on: August 17, 2017, 06:01:29 AM »
Two Please.
Gordon Tarbell AMA 15019
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #7 on: August 17, 2017, 07:39:58 AM »
I'll take one set.
« Reply #8 on: August 17, 2017, 03:51:39 PM »
2 for me.
Re: OS 40 ( forty ) VF AAC piston sleeve set IN STOCK NOW
« Reply #9 on: April 02, 2018, 02:01:47 PM »
Ok  these  are  finishing up  now, I have just shipped 7 and the others I will have fitted and ready to send
Please let me know  your Info  about shipping and payment  or call  if you have a  change in any info
 678 407 9376
I have had extras  run, so anyone  wanting a set  please let me know
Randy                 Randyaero@msn.com
Re: OS 40 ( forty ) VF AAC piston sleeve now in stock
« Reply #10 on: April 04, 2018, 10:53:15 AM »
Here are pictures that some have  asked for  of the  AAC sets
« Reply #11 on: April 05, 2018, 01:10:41 PM »
H Brett   ready to ship  call or email with your  info, I also have a little info on install and other parts to tell you
Randy   Randyaero@msn.com  678 407 9376
« Reply #12 on: April 07, 2018, 03:29:59 PM »
Re: 40 VF , OS 40 ( forty ) VF AAC piston sleeve now in stock
« Reply #13 on: April 07, 2018, 07:36:04 PM »
Hey Randy,
Maybe this is a topic for a different time but.... Is it possible to make AAC piston Sleeve sets for the OS46 (fourty-six) VF.  I would be interested in
Two (2) of those!
Why use a puny little 40 when you have several 46's like me?   <=  LL~
« Reply #14 on: April 07, 2018, 07:48:41 PM »
Hey Randy,
Two (2) of those!
Hi Randy  I did make a run of  VF 46  true  ABC, piston sleeve setup, they are  thinner  so not as heavy as the  40 VF
But  I sold them all  so  I may make another  46 VF  AAC  run  if  people  will want them
regards
« Reply #15 on: April 07, 2018, 07:54:18 PM »
Yeah, I have a couple of the ABC ones.  I would also like a couple of the AAC ones.  I have a theory that they handle the heat here in Arizona a bit better than the ABC ones!
Run one on a pipe when it's 106 degrees outside and you'll see the difference!
« Reply #16 on: April 09, 2018, 02:46:04 PM »
Hi Randy
That sound like it would be  correct, the  Sleeves I have are  aluminum, and the OS case is  Aluminum, NOTHING  has a closer expansion coefficient rate  than the AAC setup,  Brass is  close,  Steel has to be a tight press fit, so the  AAC  is  best of the  best.
I would expect  the  AAC  to be  the most stable  of  all  the  materials used
Online Lauri Malila
« Reply #17 on: April 09, 2018, 02:51:37 PM »
Hi Randy
Absolutely, especially when you forget the drop-in liner..;)
L
« Reply #18 on: April 11, 2018, 12:02:56 PM »
L
Ya  you mean just make the entire to  from Aluminum the  run the piston in the top part of the  case, doing away with the sleeve entirely ?  :-)
Online Lauri Malila
« Reply #19 on: April 11, 2018, 12:53:02 PM »
Yup, but you need a new case, too:)
By the way, is the porting exact copy of standard VF.40?
Lauri
« Reply #20 on: April 11, 2018, 03:45:41 PM »
Lauri
Lauri
It is the Exact same as the particular engine, Low Timed VF 40, That we use for  CL Stunt ships  they made higher comp  high timed version, so these are the  low time ones, Only mine are  AAC and  Hard Chrome
« Reply #21 on: April 11, 2018, 05:11:55 PM »
   Just like a McCoy 35 Redhead and an Olhsson 23, except shiny!
« Reply #22 on: April 12, 2018, 12:04:59 PM »
That AAC P/L would be nice retro fitted into some plain bushing engine like an FP40 or an LA40 but would it be much better than a Brodak 40? maybe, who knows.
If you could do it, it would still be kinda like  apples and  oranges, as  they are  really different style motors
« Reply #23 on: April 15, 2018, 09:33:43 AM »
Got my AAC VF40 P/L sets in Sat. mail. Very nice, Thanks Randy.
« Reply #24 on: April 17, 2018, 03:04:01 PM »
Your welcome  Gordon, thanks  for getting them, and  please  let me know  when you get a set into an engine
« Reply #25 on: April 19, 2018, 10:57:09 PM »
Along with the  NEW run of  AAC 40 VF, I do still have a  few  OS Stock  P/S sets  for  40 and  46
« Reply #26 on: April 25, 2018, 01:33:03 PM »
 also have a couple  of
OPS  and  OS  40  46  piston sleeve sets n stock
