  • June 29, 2025, 06:34:27 PM
Author Topic: Lets talk about Shiny Spinners!!  (Read 2808 times)
Offline James Holford
« on: April 05, 2018, 06:57:40 AM »
Im in the market for a 2" Spinner for my Gypsy and really not sure on which is good and which is bad.
 Im wanting one of those nice beautiful shiny spinners for it. Ebay is loaded with chinese cnc spinners but not sure if they are consideres good to use.
 I love the look of the old Veco spinners but having trouble finding one in 2" that isnt outrageous in price.
 Any leads on some that are good and as good looking as the old Veco's?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Lets talk about Shiny Spinners!!
« Reply #1 on: April 05, 2018, 07:14:06 AM »
TruTurn spinners are American made and are great.
A bit pricy.
http://www.truturn.com/
Offline peabody
« Reply #2 on: April 05, 2018, 07:18:57 AM »
I believe that Randy still has needle nose spinners...Aeroproducts
Brodak makes "traditional" less pointed spinners, but, alas, work is required to use a flat prop.
Have fun!
« Reply #3 on: April 05, 2018, 08:38:09 AM »
Hi James.  I have many Froom/Veco aluminum 2 inch spinners. Send me your mailing address and I'll get one off to you. Free. Just use Brasso on them and they get nice and bright, just use cotton gloves when installing them  LL~
Actually, if you put the time in using Brasso, aluminum will polish and look like chrome.
Online Tony Drago
« Reply #4 on: April 05, 2018, 12:56:58 PM »
No @#$% Sherlock,  didn't I say the exact same thing???   20 years in the Navy, trust me I know how to use Brasso. y1 y1 y1
 Good one Ty. We swore by Brasson in the military.
« Reply #5 on: April 05, 2018, 01:08:39 PM »
NO !  Sherlock  do not  do that  use  Mothers  mag and  Aluminum polish !   :-)
« Reply #6 on: April 05, 2018, 02:16:44 PM »
Don't be too nostalgic about those Froom spinners of yore.  They are pretty heavy.  Nice aluminum spinners are available from Dave Brown Products.  They polish up nicely.
Offline Robert Zambelli
« Reply #7 on: April 05, 2018, 03:16:14 PM »
I evaluated these before they went into the catalog. Very nicely made with no run-out issues at all.
  http://brodak.com/catalogsearch/result/index/?p=1&q=spinner&x=9&y=8
Offline peabody
« Reply #8 on: April 05, 2018, 03:27:35 PM »
Bob is right...the Brodak spinners are nicely made, but the prop cuts are for 6-8 pitch props....not modern stunt props.
« Reply #9 on: April 05, 2018, 03:41:23 PM »
Randy Smith spinners are "most excellent", IMO. The Brodak spinners are only slightly less wonderful, with a bit different shape. If you build the airplane to fit the spinner, the difference is very slight.  But I typically use either Dave Brown or Tru-Turn; either is excellent, but has the single screw in the pointy end and don't look quite as good. Remember that the spinner will probably save your crankshaft at some point, due to...ah, compressibility!
By the way, if you use an "electric finger" a needle nose should have better traction...especially if you use the appropriate starter insert. If you don't use an "electric finger", the needle nose spinner is a knuckle buster and you may come to use harsh words on them. If you can do a "spinner flip", either should work fine.   y1 Steve
« Reply #10 on: April 05, 2018, 04:45:08 PM »
It will be on a Gypsy built.by Mike Donavon and will be using a .46LA-S.
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #11 on: April 05, 2018, 04:48:58 PM »
Gypsy
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #12 on: April 05, 2018, 05:12:17 PM »
James,
WOW!
What a great looking model!  H^^
Really nice color choice also. Green can work!
Charles
« Reply #13 on: April 05, 2018, 05:13:35 PM »
James,
WOW!
Charles
Wish i could say I built that plane but honors gors to Mr. Donovan.
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #14 on: April 05, 2018, 09:25:23 PM »
  I don't know about availability now but I use the Great Planes 2" aluminum spinners and their mounting hardware. Decent quality and reasonable priced. I usually polish my stuff with Simichrome or this stuff I got at Oshkosh, the site of the worlds largest collection of aluminum polish vendors!
   Tooth paste and even silver polish can work in a pinch.
« Reply #15 on: April 06, 2018, 11:02:59 AM »
Not sure about toothpaste on spinners.  But I do use Brasso to brush my teeth.  I only have to be careful not to smile in public.
« Reply #16 on: April 06, 2018, 02:16:34 PM »
James, three on the way. Three different types. so one should do the job.  Use what ever polish you desire,  even vinegar and sand will do.  We used that on the Ships Bell after a few weeks at sea to remove all the verdigris.  Then we used Brasso.  H^^
You da man Ty. Thanks a ton buddy!!!!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Jared Hays
« Reply #17 on: April 06, 2018, 04:50:46 PM »
Here's what I run for mirror finish lightweight bar stock polished aluminum.
http://www.maxxprod.com/mpi/mpi-11.html
« Reply #18 on: April 06, 2018, 10:30:51 PM »
 Jared beat me to it just above here but yeah, the Pro-Spin spinners are nice and come with a nice bright polish to them. Quite a few hobby shops carry them too. Be careful not to overtighten the spinner cone on them though as it's pretty easy to warp the backplate, just get it snug and stop.
Online Dan Berry
« Reply #19 on: April 06, 2018, 10:48:13 PM »
What is this 'hobby shop' thing that you mention? Is that a place that sells unicorns?
« Reply #20 on: April 06, 2018, 11:28:00 PM »
For 2" I use the Brodak spinner with the Great Planes back plate for either Electrics or IC.   I polished the spinner with a buffing wheel on a electric drill. I use the brown polishing compound first, then the white, green or blue.. then hand polish the rest of the way with either Mothers Mag polish or something similar.
« Last Edit: April 07, 2018, 05:54:51 PM by Joe Yau »
« Reply #21 on: April 07, 2018, 02:49:37 PM »
 No kidding Dan, I thought about that as I was typing the reply, the "LHS" is practically a thing of the past anymore. However, my nearest "LHS" which is 100 miles north of me does sell unicorns.  y1
« Last Edit: April 07, 2018, 09:07:03 PM by wwwarbird »
