  • July 18, 2025, 09:23:07 AM
Author Topic: La 46 Mounting bolt template  (Read 902 times)
Offline kevin king
« on: January 18, 2022, 02:27:33 AM »
Was there ever a  mounting bolt template for the La 46? Ive always found marking the holes on the motor mounts accurately  a frustrating endeavour.
Re: La 46 Mounting bolt template
« Reply #1 on: January 18, 2022, 02:43:48 AM »
Sure. Check out Lee Machine Shop in the vender section. He lists motor mount drill guides.
Offline Dennis Nunes
« Reply #2 on: January 18, 2022, 03:33:40 AM »
Kevin,
Another tool that I've used for marking holes and getting holes drilled accurately is the Great Planes "Dead Center Engine Mount Hole Locator". This tool can be used on a variety of different engines.
Dennis
Offline kevin king
« Reply #3 on: January 18, 2022, 02:28:52 PM »
Thank you gentlemen. The only hobby shop left in my city actually had a hole locator locator in stock, saving me a month of waiting for it by mail.
« Reply #4 on: January 18, 2022, 03:44:30 PM »
     I use a homemade transfer punch, OD is the hole in the engine lug, grind a point on the end (as close to center as you can make it), 8" long, so it centers up and then leaves a divot when you tap it with a hammer.
Offline Doug Moisuk
« Reply #5 on: January 18, 2022, 04:25:37 PM »
Personally I find a problem with the Great planes one I have. If the exhaust is a little long it puts the device on an angle. So not true Center.
Doug Moisuk
MAAC 3360L
