General control line discussion => Open Forum => Topic started by: kevin king on January 18, 2022, 02:27:33 AM
Title: La 46 Mounting bolt template
Post by: kevin king on January 18, 2022, 02:27:33 AM
Was there ever a  mounting bolt template for the La 46? Ive always found marking the holes on the motor mounts accurately  a frustrating endeavour.
Title: Re: La 46 Mounting bolt template
Post by: Dave Hull on January 18, 2022, 02:43:48 AM
Sure. Check out Lee Machine Shop in the vender section. He lists motor mount drill guides.
Post by: Dennis Nunes on January 18, 2022, 03:33:40 AM
Kevin,
Another tool that I've used for marking holes and getting holes drilled accurately is the Great Planes "Dead Center Engine Mount Hole Locator". This tool can be used on a variety of different engines.
Dennis
Post by: kevin king on January 18, 2022, 02:28:52 PM
Thank you gentlemen. The only hobby shop left in my city actually had a hole locator locator in stock, saving me a month of waiting for it by mail.
Post by: Brett Buck on January 18, 2022, 03:44:30 PM
     I use a homemade transfer punch, OD is the hole in the engine lug, grind a point on the end (as close to center as you can make it), 8" long, so it centers up and then leaves a divot when you tap it with a hammer.
Post by: Doug Moisuk on January 18, 2022, 04:25:37 PM
Personally I find a problem with the Great planes one I have. If the exhaust is a little long it puts the device on an angle. So not true Center.
