  • June 24, 2025, 09:58:55 PM
Author Topic: O S L A 46 cyl heads  (Read 1066 times)
Offline Bootlegger
« on: October 09, 2014, 09:19:55 AM »
 Guy's if any one has crashed, and broken an OS LA 46 if you still have the stock head would you let me know?
 Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline john gunn
Re: O S L A 46 cyl heads
« Reply #1 on: October 09, 2014, 01:50:11 PM »
There should have a interesting story behind this unusual request
Offline Brian Massey
    • California Car Clubs
« Reply #2 on: October 09, 2014, 06:11:07 PM »
Thinking the same thing.
AMA 55421
Madera, CA
« Reply #3 on: October 09, 2014, 09:41:39 PM »
I suspect that Gil is trying to remachine stock heads to make the .46LA do 4-2-4 runs. It appears that there are no heads available from Tower Hobby, so he's doing the right thing, I think, but don't think the heads need rework. He probably did not consider making one stock head into a clamp and going to barstock "button heads". This is generally an easier way to do it, especially since the LA heads are such a silly exterior shape. Don't take any .40LA heads, Gil...the bolt pattern is smaller!  H^^ Steve
« Reply #4 on: October 10, 2014, 11:49:31 AM »
Steve; I have an LA 46 with 400+ flights and get a great 4-2 break. It has two added head shims and uses 10% nitro. For a "cheap" motor, it's great.
Brian
AMA 55421
Madera, CA
